AAF suffer with reduced CMRR because of Passives Tolerances
Question asked by jebaspaul on Oct 28, 2013
Latest reply on Nov 6, 2013 by Matt.Duff
I am working on differential Multi-channel high precision DAS. I have chosen the following architectures.
Spec: CMRR -  >=50dB @ 0 to 1Khz
         Gain Error - 0.02%
Architecture 1:
AAF --> MUX --> IA --> Post amplifiers --> ADC
But, the demand in CMRR forced me to drop this architecture. Since the signal line is differential, a small variation in passives used for filtering reduce the CMRR by a huge margin. In particular getting precised value capacitor with less tolerance demands more money. I used 2nd order butter-worth filter. But this architecture doesn't give any head ache on Gain error. Except AAF all other components are common for each channel, so the gain error caused by these components can be software calibrated.
This architecture fails to satisfy CMRR spec.
Architecture 2:
IA (diff to single ended) --> filter --> BUFF --> MUX --> BUFF --> Single to differential --> ADC
This architecture gives leverage in choosing passives for filter since the signal is converted into single ended. But, gain of IA is controlled by passive resistors. Even the resistors are present inside the IC & laser trimmed, the maximum gain error is around 0.01%. But those IC's having gain error of 0.01% are costly. According to my specs the maximum allowed gain error is 0.02%.
This architecture fails to satisfy Gain error spec.
Components used : MUX ADG1207, IA - AD8421, Single to differential - AD8513, ADC - AD7663
Is that arrived conclusion about each architecture correct. Please suggest some ways to get out of this situation.
Jebas.
