Error when build kernel to support MCAPI
Question asked by pengpeng on Oct 23, 2013
Latest reply on Oct 28, 2013 by Aaronwu
Hi Aaronwu,
Thanks for your suggestions, I am able to use svn to retrieve all the packages and build my own kernel uImage (bf609 default). Now I am exploring the multicore communication feature (after make mrproper in linux/linux-kernel and make clean in adi-buildroot-code folder, seperately). Then,
Following exactly according to: http://blackfin.uclinux.org/doku.php?id=test_icc, I have reached the stage:
make packages/icc_utils_only
saying that no rule to make it. I checked that folder, there is no makefile. So I was wondering where could it be?
Then I skipped this and followed:
http://blackfin.uclinux.org/doku.php?id=test_mcapi
to get a kernel image which supports MCAPI.
Then I got error when:
make libmcapi
under adi-buildroot-code directory. The error message and log files are listed as below:
configure: WARNING: unrecognized options: --disable-gtk-doc, --disable-nls, --disable-ipv6
configure: error: in `/home/y/adi-buildroot-code/output/build/libmcapi-668/libmcapi-2.0':
configure: error: C compiler cannot create executables
See `config.log' for more details
make: *** [/home/y/adi-buildroot-code/output/build/libmcapi-668/.stamp_configured] Error 7
Any ideas? Thanks,
