ADSP21262 as SPI slave
Question asked by sander on Jun 2, 2010
Latest reply on Jun 7, 2010 by jeyanthi.jegadeesan
I'm using an ADSP-21262 which is configured to boot from a spi slave eeprom.
When the program is executed I want the ADSP to act as an spi slave with DMA support.
The master is some microcontroller which communicates with the ADSP as if it where
a spi memory chip.
During communication, the master microcontroller starts with sending 4 control bytes:
byte 0: Opcode,     Read/Write
byte 1: Length,      length of read/write data after control block.
byte 2: address.    read/write address (MSB)
byte 3: address.    read/write address (LSB)
After the control bytes are received by the ADSP a interrupt should be generated.
In this interrupt the DMA pointers will be set to the given address and data will be received/send for the given length.
In the picture below I've made a schematic of what I beleive is the right connection between microcontroller, dsp and eeprom.
Can you tell me if this schematic is correct?!
Is there a software example which implements a spi slave with DMA support?!
Kind Regards
Sander
