NxM Mixer Export Bug in SigmaStudio 3.9 on ADAU1446
Question asked by tompdx on Oct 10, 2013
Latest reply on Nov 19, 2013 by wsierra
When we create an NxM Mixer in SigmaStudio 3.9 and download that file into the ADAU1446, it compiles quickly, downloads properly, and works as advertised.
However, when you then go to export system files, and look at your XXXXXX_IC_1_PARAM.h file, the export step requires longer than it should. and you will note that your NxM mixer has exponentially more nodes than it requires.
For example, we did a 13 x 16 mixer, and the Parameters for that mixer  took up 173,058 lines of the  XXXXXX_IC_1_PARAM.h text file.  This file took over 18 minutes to export the system files on a fast machine.  We could post process the PARAM.h file and remove the duplicate entries if that was the only problem.  However, development screeches to a halt when it takes 18 minutes to export the system files.
Below is a single node at address 458, and I included some from address 459 as well,  from that parameter file.  It repeats multiple times.  Note how the same address is used repeatedly.  This bug causes huge PARAM.h files and huge export times.
----- Begin attached porttion of PARAM.h file -----
/* Module MAIN MIXER - NxM Mixer*/
#define MOD_MIXER_MAINMIXER_COUNT                      43264
#define MOD_MIXER_MAINMIXER_DEVICE                     "IC1"
#define MOD_MIXER_MAINMIXER_ALG0_NXNMIXER1940ALG100_ADDR 458
#define MOD_MIXER_MAINMIXER_ALG0_NXNMIXER1940ALG100_FIXPT 0x00000000
#define MOD_MIXER_MAINMIXER_ALG0_NXNMIXER1940ALG100_VALUE SIGMASTUDIOTYPE_FIXPOINT_CONVERT(1E-10)
#define MOD_MIXER_MAINMIXER_ALG0_NXNMIXER1940ALG100_TYPE SIGMASTUDIOTYPE_FIXPOINT
#define MOD_MIXER_MAINMIXER_ALG0_NXNMIXER1940ALG101_ADDR 459
#define MOD_MIXER_MAINMIXER_ALG0_NXNMIXER1940ALG101_FIXPT 0x00A12477
#define MOD_MIXER_MAINMIXER_ALG0_NXNMIXER1940ALG101_VALUE SIGMASTUDIOTYPE_FIXPOINT_CONVERT(1.25892541179417)
#define MOD_MIXER_MAINMIXER_ALG0_NXNMIXER1940ALG101_TYPE SIGMASTUDIOTYPE_FIXPOINT
