Can you remove files from a .dlb
Question asked by MikeSmithCanada on May 30, 2010
Latest reply on Jun 4, 2010 by CraigG
Two core project made by VDSP on 561 where coreA is a library
CoreA.dlb has a main.doj that calls
     first( ) in first.doj -- part of the coreA.dlb
     second( )  in second.doj -- part of the coreA.dlb
     third( ) in   third.doj -- part of another.dlb
Build the project and load onto cores
   Can check that the files are loaded by clicking on file and going to mixed mode.
   If file is loaded, then mixed mode opens
Now remove first.cpp from the CoreA
Copy first.cpp as  firstcopy.cpp  (with first( )  ) inside
     and make first a part of another.dlb project
Now rebuild project group -- using Build all command
     The version of first( ) inside firstcopy.cpp in another.dlb is not loaded
     The version of first( ) inside first.cpp in coreA.dlb is still loaded
          even though that file is not part of the library build and longer
     The only was I can seem to fix this problem is to do a clean on coreA project
          Updating the dependencies (to show removal of first.cpp from the library) does not work
I don't feel that this is a desirable behaviour -- is it possible to force removal of a .doj from a .dlb without doing a clean?
