HDL Version 2 BUILD timing errors.....
Question asked by ROBFRO on Oct 8, 2013
Latest reply on Nov 11, 2013 by DragosB
I am trying to BUILD the latest no-os demonstration.
I downloaded this HDL Version 2 design.
fpgahdl_xilinx-ad_fmcomms1_ebz_edk_14_4_2013_08_23
I am getting timing errors.
INFO:Timing:3412 - To improve timing, see the Timing Closure User Guide (UG612).
INFO:Timing:2752 - To get complete path coverage, use the unconstrained paths option. All paths that are not constrained will be reported in
   the unconstrained paths section(s) of the report.
INFO:Timing:3339 - The clock-to-out numbers in this timing report are based on a 50 Ohm transmission line loading model.  For the details of
   this model, and for more information on accounting for different loading conditions, please see the device datasheet.
Timing summary:
Timing errors: 7  Score: 965 (Setup/Max: 965, Hold: 0)
Constraints cover 8706053 paths, 2 nets, and 354517 connections
Design statistics:
   Minimum period:  11.613ns (Maximum frequency:  86.110MHz)
   Maximum path delay from/to any node:   5.364ns
   Maximum net skew:   2.977ns
   Maximum output delay after clock:   2.816ns
Analysis completed Tue Oct 08 11:53:01 2013
Generating Report ...
Number of warnings: 9
Number of info messages: 4
Total time: 3 mins 52 secs
xflow done!
touch __xps/system_routed
xilperl C:/xilinx/14.4/ISE_DS/EDK/data/fpga_impl/observe_par.pl -error yes implementation/system.par
Analyzing implementation/system.par
ERROR: 1 constraint not met.
PAR could not meet all timing constraints. A bitstream will not be generated.
To disable the PAR timing check:
1> Disable the "Treat timing closure failure as error" option from the Project Options dialog in XPS.
2> Type following at the XPS prompt:
XPS% xset enable_par_timing_error 0
make: *** [implementation/system.bit] Error 1
Done!
Any suggestions?
