AD9512 Clock Divider Comms Problem
Question asked by dannybeckett on Oct 8, 2013
Latest reply on Oct 14, 2013 by Kyle.Slightom
I have prototyped an AD9512 on a double layer PCB before it's integrated into an existing project. The schematic & layout are as follows:
The device powers on with no problem. I'm using an explorer16 pic dev kit to write to the chip. The SPI seems to be operating without issue. When I power the chip on, I get a 30MHz clock output from pin 35, divider 3, from a 60MHz clock in. This is correct since the default values cause the dividers to operate at /2:
I cannot get the chip to do anything via SPI serial commands. I am writing out the following sequence:
*CS low*
0x00     // write, 1 data byte
0x51     // divider 3 config buffer address
0x80     // bypass divider
*CS high*
*CS low*
0x5A     // update registers address
0x01     // update registers
*CS high*
This sequence does not alter the output of the chip whatsoever. The following screenshots are of the SPI lines going to the chip.
Blue = CSB
Purple = SDIO
Green = SCLK
A read of the chip causes erreonus outputs to occur. I am not sure why this happens.
