I am working with ADSP21060 processor. I used TIMER0 interrupt to periodically execute a task . Plz explain the interrupt working flow
Question asked by sulficker on Oct 3, 2013
Latest reply on Oct 4, 2013 by MaheshN
Question : I am working with 21060 processor. To periodically execute a task in every 0.5 ms i use a TIMER0 interrput. Pseudo code is attached. Here i am calling   interrupt (SIG_TMZ0,timer_isr). Once the timer_isr() function completes where the control will be coming. Is it comes to the point asm("wait:nop;\
    jump wait;"); or at the start of main because i am using nope at the end of timer_isr(). How the RTI instruction is embedded in the module, since i am not wrinting RTI as i have implemented the code in C language. Is RTI is taken care by the call interrupt (SIG_TMZ0,timer_isr)?
void main()
// Initialising the Serial Ports of ADSP21060
    init();
    //Initialising the DAC's with all zeroes
    position_op1 = 0;
    position_op2 = 0;
    adcip = 0;
    prev_adcip = 0;
       Va1 = 3.3941;
    Va2 = 3.3941;
    Vb1 = 3.3941;
    Vb2 = 3.3941;
    hall_loop1 = 0x00000000;
    hall_loop2 = 0x00000000;
    for(i=0;i<N;i++)
        x[i] = 0;
        y[i] = 0;
        dx[i] = 0;
  /*timer_set(unsigned int tperiod, unsigned int tcount)
  time between int = 500 us */
    if((timer_set(15151,15151)!=1))
        hold_tcount = timer_on();
    interrupt (SIG_TMZ0,timer_isr);
    asm("wait:nop;\
    jump wait;");
void timer_isr()
    simc25(adcip1, &prev_adcip1, y_loop1, &flag_loop1, &f_sign_loop1, &position_op1, &Va1, &Vb1, &hall_loop1);
    mul_dac_loop1();
    simc25(adcip2, &prev_adcip2, y_loop2, &flag_loop2, &f_sign_loop2, &position_op2, &Va2, &Vb2, &hall_loop2);
    mul_dac_loop2();//implemented in assembly
    asm("nop;");
void simc25(float adcip, float *prev_adcip, float y[], unsigned int* flag_in, float* sign_in, float* position_op, float *Va, float *Vb, unsigned int* hall_input)
    adcip_m = adcip;                //ADC input
    prev_adcip_m = *prev_adcip;     //Disturbance
    u = (adcip+*prev_adcip)/2;
    u1 = (adcip_m+prev_adcip_m)/2;
    for (i=0; i<N; i++)
        states[i] = y[i];
....Some logics implemented here
   *Va = y[3];
    *Vb = y[4];
    *prev_adcip = adcip;
