Question on Receiving Data Via UART
Question asked by spdavis on Oct 2, 2013
Latest reply on Oct 4, 2013 by spdavis
Hello All,
     I am using the SHARC EZ-Lite 21469 Evaluation Board and VisualDSP++.  I am have written a simple program under the VDK to transmit and receive messages via the UART on the Eval Board.  I have a serial cable connected from my PC serial port to the SHARC Eval Board serial port.  I am able to send messages to the terminal emulator on the PC. That part of the program works well.
    My problem is receiving a string from the PC to the Eval Board.  When I receive the string from the PC,I can only seem to retrieve the first character in the string.  In the ISR routine, I have the following code in my ISR to retrieve the characters:
void P13I_Entry(void) {
/* Insert your ISR code here */
int value;
int count = 0;
value = *pUART0RBR;
char_recvd[count] = value;
count++;
while ((*pUART0LSR & UARTDR) == 1)
           count++;
flag = 1;
I would have expected char_recvd[] to capture all the characters in the sent string.  However it only captures the first character of the string.
It looks like the first character is captured by the first "char_recvd[count] = value" statement.  I would have thought the additional characters would be retrieved in the while loop, but this does not seem to be the case.
I am just starting embedded programming, so I may be missing something obvious.  I did try clearing the UARTDLAB bit (bit 7 of the UART0LCR register) at the end of the loop, but that did not help.
Note that "char_recvd[]" and "flag" are global variables.  The string I am sending from the PC to the SHARC will always consist of 10 characters.
Thanks for any help!
Stephen
