Kernel and jffs2 in spi-flash
Question asked by vrp on Oct 1, 2013
Latest reply on Oct 4, 2013 by vrp
My steps:
1. tar -vxf blackfin-buildroot-2012R2-RC5.tar
2. cd  blackfin-buildroot/
3. make bf537-stamp_defconfig
4. make
The resulting uImage is loaded and runs just right.
Now I want to generate the Kernel with root file system and save them in the serial flash.
According to topics
     http://docs.blackfin.uclinux.org/doku.php?id=linux-kernel:mtd
     http://docs.blackfin.uclinux.org/doku.php?id=linux-kernel:jffs&s%5b%5d=vmimage
we choose (or not) the following options:
make linux-menuconfig
     Device Drivers  --->
           <*> Memory Technology Device (MTD) support  --->
               <*>   Direct char device access to MTD devices
               <*>   Caching block device access to MTD devices
               Mapping drivers for chip access  --->
                    [*] Support non-linear mappings of flash chips
                    [ ] Generic uClinux RAM/ROM filesystem support
               Self-contained MTD device drivers  --->
                    <*> Support most SPI Flash chips (AT26DF, M25P, W25X, ...)
     File systems  --->
          [*] Miscellaneous filesystems  --->
               <*>   Journalling Flash File System v2 (JFFS2) support
After 'make' we get uImage, vmImage, and rootfs.jffs2.
bfin> tftp 0x1000000 uImage
bfin> bootm
uImage is booting and runs quite right. It shows in particular:
     m25p80 spi0.1: found m25p64, expected m25p80
     m25p80 spi0.1: m25p64 (8192 Kbytes)
     Creating 3 MTD partitions on "m25p80":
     0x000000000000-0x000000040000 : "bootloader(spi)"
     0x000000040000-0x0000001c0000 : "linux kernel(spi)"
     0x0000001c0000-0x000000800000 : "file system(spi)"
Now we erase the entire device
     bfin> sf probe 1
     SF: Detected M25P64 with page size 64 KiB, total 8 MiB
     bfin> mw.b 0x1000000 0x0 0x800000
Save U-Boot in the spi-flash:
     tftp 0x1000000 u-boot.ldr
     Bytes transferred = 210770 (33752 hex)
     sf write 0x1000000 0x0 $(filesize)
Load and save vmImage:
     bfin> mw.b 0x1000000 0x0 0x180000
     bfin> tftp 0x1000000 vmImage
     Bytes transferred = 1146813 (117fbd hex)1c
     bfin> sf write 0x1000000 0x40000 0x180000
Load and save rootfs.jffs2:
     bfin> tftp 0x1000000 rootfs.jffs2
     Bytes transferred = 2902708 (2c4ab4 hex)
     bfin> sf write 0x1000000 0x1c0000 $(filesize)
Prepare parameters of the U-Boot:
     bfin> setenv bootargs root=/dev/mtdblock2 rw rootfstype=jffs2
     bfin> setenv flashboot 'sf probe 1; sf read 0x1000000 0x40000 0x180000; bootm 0x1000000'
     bfin> setenv bootcmd run flashboot
     bfin> save
After
     bfin> run bootcmd
there is the following dump:
## Booting kernel from Legacy Image at 01000000 ...
   Image Name:   bf537-0.2-3.5.7-ADI-2012R2
   Created:      2013-10-01  11:17:04 UTC
   Image Type:   Blackfin Linux Kernel Image (gzip compressed)
   Data Size:    1146749 Bytes = 1.1 MiB
   Load Address: 00001000
   Entry Point:  001f1d28
   Verifying Checksum ... OK
   Uncompressing Kernel Image ... OK
Starting Kernel at = 001f1d28
console [ttyBF0] enabled, bootconsole disabled
Calibrating delay loop... 995.32 BogoMIPS (lpj=1990656)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
devtmpfs: initialized
Blackfin Scratchpad data SRAM: 4 KB
Blackfin L1 Data A SRAM: 16 KB (16 KB free)
Blackfin L1 Data B SRAM: 16 KB (16 KB free)
Blackfin L1 Instruction SRAM: 48 KB (34 KB free)
NET: Registered protocol family 16
Blackfin DMA Controller
stamp_init(): registering device resources
bio: create slab <bio-0> at 0
bfin-spi bfin-spi.0: master is unqueued, this is deprecated
bfin-spi bfin-spi.0: Blackfin on-chip SPI Controller Driver, Version 1.0, regs@ffc00500, dma channel@7
Switching to clocksource bfin_cs_cycles
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 1024 (order: 1, 8192 bytes)
TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
TCP: Hash tables configured (established 1024 bind 1024)
TCP: reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
Kernel panic - not syncing: junk in compressed archive
Hardware Trace:
   0 Target : <0x0014ff48> { _dump_stack + 0x0 }
     Source : <0x0014ffe8> { _panic + 0x68 } CALL pcrel
   1 Target : <0x0014ffd6> { _panic + 0x56 }
     Source : <0x0000c31e> { _test_taint + 0x22 } RTS
   2 Target : <0x0000c2fc> { _test_taint + 0x0 }
     Source : <0x0014ffd2> { _panic + 0x52 } CALL pcrel
and so on.
What did I forget? Thank you.
