Questions on software interrupt and number of callback functions on CCES
Question asked by nigong on Sep 26, 2013
Latest reply on Oct 2, 2013 by SteveM
Question1:
I wanted to use raise instruction to generate software interrupt so that I can test the program without actually tackling the hardware. I am using BF533.
I set up an push button (GPIO) interrupt and it worked fine. Here is the code how I set it up:
void main(){
sicResult = adi_sic_SetIVGLevel(
                        (uint32_t)          ADI_SID_PFA,          // System Interrupt ID
                        (uint32_t)          12u);                              // IVGLevel
    CheckResult(result);
    int inParam = 5;
    intResult = adi_int_InstallHandler(
                        (ADI_INT_HANDLER_PTR)                    PFAIntHandler,
                        (void *)                                                  &inParam,
                        (bool)                                                            true
    CheckResult(intResult);
static void PFAIntHandler(uint32_t iid, void* handlerArg)
          intCount++;
          *pFIO_FLAG_C = 0x100 | 0x200;
Then I tried to use the raise instruction:
raise_intr (12);
It didn't go to the interrupt handler (PFAIntHandler), neither it sets the 12th bit of ILAT.
However, if I try:
raise_intr (1);
It did reset the processor.
I am wondering if the raise instruction still works on all the interrupts on CCES. If not, what is the substitute function of it on CCES?
Question 2:
Since I built this on top of the GPIO push botton and LED example provided by CCES examples, the push buttons already have a callback function (blinking the LEDs) matched. But if I set a interrupt on the push button, the original callback function would not be called. It seems like CCES only allows one "callback" to be called, or the interrupt handler I wrote clears the related bits that trigger the original callback function.
Am I understanding correctly?
Dongcheng
