LIB Macros missing from automatically generated LDF
Question asked by charliec on Sep 25, 2013
Latest reply on Sep 26, 2013 by charliec
Hi -
Current LDFs use for our Blackfin 561 VDK application have  RT_LIB_NAME's Macros defined in the CoreA/CoreB LDF files as shown below.  The LDF's are checked in/out of source control and not allowed to be re-generated at VisualDSP++ startup time.  Currently used VisualDSP++ is 5.0.8.
/* MANAGED-BY-SYSTEM-BUILDER                                */
/* VisualDSP++ 5.0 Update 6                                 */
/* LDF Printer version: 5.6.0.4                             */
/* ldfgen.exe version: 5.6.0.4                              */
/* VDSG version: 5.6.0.4                                    */
** ADSP-BF561 linker description file generated on Feb 09, 2010 at 16:29:00.
** Copyright (C) 2000-2008 Analog Devices Inc., All Rights Reserved.
** This file is generated automatically based upon the options selected
** in the LDF Wizard. Changes to the LDF configuration should be made by
** changing the appropriate options rather than editing this file.
** Configuration:-
** crt_doj:                            CoreA_basiccrt.doj
** processor:                          ADSP-BF561
** product_name:                       VisualDSP++ 5.0 Update 6
** si_revision:                        automatic
** default_silicon_revision_from_archdef:  0.5
** using_cplusplus:                    true
** mem_init:                           false
** use_vdk:                            true
** use_eh:                             true
** use_argv:                           false
** running_from_internal_memory:       true
** user_heap_src_file:                 D:\AwsDSP\Software\LtSensor_v2008\CoreA\CoreA_heaptab.c
** libraries_use_stdlib:               true
** libraries_use_fileio_libs:          false
** libraries_use_ieeefp_emulation_libs:false
** libraries_use_eh_enabled_libs:      false
** system_heap:                        L2
** system_heap_min_size:               30k
** system_stack:                       SCRATCHPAD
** system_stack_min_size:              3k
** use_sdram:                          true
** use_sdram_size:                     64MB
** use_sdram_partitioned:              default
** num_user_heaps:                     1
** user_heap0:                         L3
** user_heap0_min_size:                8000k
** user_heap0_heap_name:               heapSDRAM
** use_multicores:                     2
** use_multicores_use_core:            coreA
ARCHITECTURE(ADSP-BF561)
SEARCH_DIR($ADI_DSP/Blackfin/lib)
#define VDK_LDF_
#include "VDK.h"
// Setup the VDK library preprocessor macros
#if VDK_INSTRUMENTATION_LEVEL_==2
#define VDK_IFLAG_ i
#elif VDK_INSTRUMENTATION_LEVEL_==1
#define VDK_IFLAG_ e
#else
#define VDK_IFLAG_ n
#endif
#define VDK_LIB_NAME_MACRO_(x) vdk- ## x ## -BF561.dlb
#define VDK_LIB_NAME_(x) VDK_LIB_NAME_MACRO_(x)
// Workarounds are enabled, exceptions are disabled.
#define RT_LIB_NAME(x) lib ## x ## y.dlb
#define RT_LIB_NAME_EH(x) lib ## x ## y.dlb
#define RT_LIB_NAME_MT(x) lib ## x ## mty.dlb
#define RT_LIB_NAME_EH_MT(x) lib ## x ## mty.dlb
#define RT_OBJ_NAME(x) x ## y.doj
#define RT_OBJ_NAME_MT(x) x ## mty.doj
#define LIBS \
   TMK-BF561.dlb \
   ,VDK_LIB_NAME_(CORE) \
   ,VDK_LIB_NAME_(VDK_IFLAG_) \
   ,RT_LIB_NAME(small561) \
   ,RT_LIB_NAME_MT(io561) \
   ,RT_LIB_NAME_MT(c561) \
   ,RT_LIB_NAME_MT(event561) \
   ,RT_LIB_NAME_MT(x561) \
   ,RT_LIB_NAME_EH_MT(cpp561) \
   ,RT_LIB_NAME_EH_MT(cpprt561) \
   ,RT_LIB_NAME(f64ieee561) \
   ,RT_LIB_NAME(dsp561) \
   ,RT_LIB_NAME(sftflt561) \
   ,RT_LIB_NAME(etsi561) \
   ,RT_LIB_NAME(ssl561_vdk) \
   ,RT_LIB_NAME(drv561) \
   ,RT_LIB_NAME(usb561) \
   ,RT_OBJ_NAME_MT(idle561) \
   ,RT_LIB_NAME(rt_fileio561) \
$LIBS = LIBS;
If I allow VisualDSP++ to generate LDF's at startup, the LDF's are missing the RT_LIB_NAME macros,
/* VisualDSP++ 5.0 Update 8                                 */
/* LDF Printer version: 5.9.0.1                             */
/* ldfgen.exe version: 5.8.0.3                              */
/* VDSG version: 5.9.0.1                                    */
** ADSP-BF561 linker description file generated on Sep 25, 2013 at 09:58:21.
** Copyright (C) 2000-2010 Analog Devices Inc., All Rights Reserved.
** Configuration:-
** product_name:                       VisualDSP++ 5.0 Update 8
** si_revision:                        any
** mem_init:                           false
** use_vdk:                            true
** use_eh:                             true
** use_argv:                           false
** user_heap_src_file:                 C:\gitwork\ltsensordsp_4.0.toga.Release.20130924\src\ltsensordsp\CoreA\CoreA_heaptab.c
** libraries_use_eh_enabled_libs:      true
** libraries_use_utility_rom:          true
** system_heap:                        L2
** system_heap_min_size:               28k
** use_sdram:                          true
** user_heap0:                         L3
** use_multicores_use_mt:              true
#define VDK_LDF_
#include "VDK.h"
#else
#endif
#define LIBS \
   RT_LIB_NAME(mc561) \
   ,TMK-BF561.dlb \
$LIBS =
I've tried changing the various switches via the Project->Link Project->Compile,  and Project->LDF settings, but none of the changes will generate the RT_LIB_NAME macro definitions in the LDF files.
What Project setting will force the inclusion of the RT_LIB_NAME Macros in the LDF files?
- Charlie
