SPI Flash parameters for U-boot again
Question asked by vrp on Sep 25, 2013
Latest reply on Sep 26, 2013 by vrp
I have a board based on BF537 with very old U-Boot in a NAND flash. So, I can load images to memory. There is also a spi-flash (8 MiB). It works with old U-Boot. Now I try to load into the spi-flash the U-Boot 2012.
The file bf537-stamp.h contains the lines:
#define CONFIG_BFIN_BOOT_MODE       BFIN_BOOT_SPI_MASTER
* Memory Settings
#define CONFIG_MEM_ADD_WDTH          9
#define CONFIG_MEM_SIZE                    32               // There is such memory
* SPI Settings
#define CONFIG_BFIN_SPI
#define CONFIG_SPI_FLASH
#define CONFIG_CMD_SF
#define CONFIG_SF_DEFAULT_SPEED          30000000
#define CONFIG_SF_DEFAULT_MODE          SPI_MODE_3
#define CONFIG_SPI_FLASH_ALL
#if (CONFIG_BFIN_BOOT_MODE == BFIN_BOOT_SPI_MASTER)
#define CONFIG_ENV_IN_SPI_FLASH
#define CONFIG_ENV_SPI_MAX_HZ          30000000
#define CONFIG_ENV_SPI_MODE          SPI_MODE_3
#define CONFIG_ENV_SPI_BUS          0
#define CONFIG_ENV_SPI_CS          1
#else
#endif
#define CONFIG_SPI_FLASH_STMICRO
Compilation is successful. Then I run commands:
bf537> tftp 0x1000 u-boot.bin
Using BF537 ETHERNET device
TFTP from server 192.168.21.2; our IP address is 192.168.21.3
Filename 'u-boot.bin'.
Load address: 0x1000
Loading: #########################################
done
Bytes transferred = 206152 (32548 hex)
bf537> go 0x1000
## Starting application at 0x00001000 ...
U-Boot 2012.07-rc2 (ADI-2012R2) (Sep 25 2013 - 18:15:47)
CPU:   ADSP bf537-0.2 (Detected Rev: 0.2) (spi flash boot)
Board: ADI BF537 stamp board
       Support: http://blackfin.uclinux.org/
Clock: VCO: 500 MHz, Core: 500 MHz, System: 125 MHz
RAM:   32 MiB
Flash: 4 MiB
MMC:
SF: Detected M25P64 with page size 64 KiB, total 8 MiB
In:    serial
Out:   serial
Err:   serial
KGDB:  [on serial] ready
Warning: Generating 'random' MAC address
Net:   bfin_mac
Hit any key to stop autoboot:  0
bfin> sf probe 1
Everything is good!
Then I write the U-Boot into spi-flash by means of two macros:
load1=mw.b 0x1000000 0x0 0x800000;eeprom write 0x1000000 0x0 0x800000
load2=tftp 0x1000000 u-boot.ldr;eeprom write 0x1000000 0x0 $(filesize)
And the U-Boot does not want to start. Where should I find a mistake?
