ADV7341 DAC - Setting levels for S Video
Question asked by DunbarB on Sep 24, 2013
Latest reply on Sep 26, 2013 by GuenterL
Hi, I'm using ADV7341.
Basic problem is I can't get levels correct for LumaChroma outputs in SVideo mode.
I have 525 YCbCr input with TRS timing method, and am wanting CVBS - Luma - Chroma on DAC1,2,3 outputs respectively.
I also want the CVBS and Luma output to have no pedestal, and be 714 mV full range for white-blanking.
I started with your Table 65 script in the datasheet, but modified it a bit like so:
Addr/Data writes follow:
1702 - same as yours
00FC - same
0100 -same
0210 - put out YPrPb instead of RGB
8010 - same
82C3 - change so we can get Luma on DAC2 and Chroma on DAC3
8810 - same
So in this setup my composite looks pretty good, but Luma and chroma need 'just a bit' of adjustment, they are within about 2% of where they need to be:
Luma is 980 mV, should be 1000.  Chroma is 890 mV, should be 903.
I write a 01 to reg87, which allows scaling control of 'Luma and Color Scale' according to datasheet.
I write a 82 to reg9D, and I can successfully get my Luma output levels where they should be.
But when I write gain values to reg9E, I can change Chroma levels but can't get them to where they need to be.
The chroma levels seem to saturate at about 650 mV p-p...
They were higher than this before I wrote reg87
What am I missing?
