Build dependency issue after rebuild of a library
Question asked by MikeSmithCanada on Sep 15, 2013
Latest reply on Mar 25, 2014 by JohnRedford
I thought I found the answer and deleted the thread -- however CCES does not work as expected for this dependency between two projects
Have two projects
Test project accesses the Library project via a linker property
and what I thought implied a dependency
I make changes to library -- build
I make changes to tests -- build
Then the test code uses changed library
If I make changes to library -- build
and then build the test code
then the 'make' program does not take into account the changed date on library.dlb and does not do a build
I have to force a clean on tests to get it to use the new library (or at least make a change in one of the test files
I would consider this functionality "incorrect"
Is there something I can do to force the use of the new library automatically
Thanks
Mike
