Improve AD8218 accuracy
Question asked by DanTheMan on Sep 13, 2013
Latest reply on Sep 16, 2013 by Emman.A
I need to measure high side current 0-24mA, with a high accuracy 0.1mA, during a -10 - +125deg temperature.
The AD8218 seems to be a nice component, but when i starting to calculate there are way to inaccurate. Most of the error is comming from GAIN and Voltage Offset errors. I can do callibration in the production of each product, to eventually improve accuracy, but I need to understand whats the datasheet say to me. Please help me to demystify the values below:
from datasheet:
http://www.analog.com/static/imported-files/data_sheets/AD8218.pdf
Gain Initial Accuracy                                  Typ:+-0.1%
     Is this a gain offset at 25C, that can be removed by calibration in 25C?
Gain Initial Accuracy over temperature         Max:+-0.35%
      Is this a gain offset at whole temp range? In this case why is then +-5ppm/C stated? Can this be removed by calibration in 25C?
Gain Initial Temp vs temperature                  +-5ppm/C
      Normally I would beleve that this is the gain change over temperature but whit a  Gain Initial Accuracy over temperature in the datasheet I      dont know what this data means any more?
Voltage Offset-Voltage Offset                                    Max:+-200uV
     Is this a Voltage offset at 25C, that can be removed by calibration in 25C?
Voltage Offset-Voltage Offset Over Temperature        Max:+-300uV
      Is this a Voltage Offset at whole temp range? In this case why is then +-100nV/C stated? Can this be removed by calibration in 25C?
Voltage Offset-Offset Drift                                       +-100nV/C
      Normally I would beleve that this is the Offset change over temperature but whit a  Voltage Offset-Voltage Offset Over Temperature in the       datasheet I dont know what this data means any more?
