Calibration setup ADE7878
Question asked by Baex on Sep 11, 2013
Latest reply on Sep 24, 2013 by Baex
Hi Analog Device people,
I have connected and external micro controller to the ADE7878 eval board via a SPI interface.
I can read out all the RMS values. I am using current transformers with a specified phase shift.
I have set the according correction value in the xPHCAL registers.
Now I need to calibrate the voltage and current gains.
Voltage calibration:
My voltage supply over here is not very stable and varies. What calibration setup would you recommend for calibration?
What are you using as a reference?
Is it possible to calibrate the meter with a DC voltage, if I switch of the input high pass filter?
Is it possible to calibrate the gain and offset according to that image above ?
Gain  = (U2-U1) / (U2out - U1out)
Offset = U1*Gain - U1
Current calibration:
I want to measure about 100A in a 3 phase 400V net. Which accuracy can I reach without offset calibration.
What is your strategy to calibrate the offset?  How do you generate a stable AC current value?
many thanks.
Best Regards
Max
