ADXL345 C++11 conversion
Question asked by mwpowellhtx on Sep 9, 2013
Latest reply on Sep 20, 2013 by neilzhao
I am adapting an ADXL345 into our mobile application, and I'd like to get some feedback. I've got an accelerometer_data_t structure that basically maps the X, Y, and Z in terms of a float-based solution: i.e. for easier subsequent transformations, translations, etc.
However, there's the matter of lifting the data out from the read-buffer in the first place before that ship leaves port, so to speak. So here goes:
Sample Code
* \brief Directs the buffer into the data.
* \param data An accelerometer-data reference.
* \param buffer A buffer reference.
* \returns The data reference.
accelerometer_data_t& operator<<(accelerometer_data_t& data, const buffer_type& buffer) {
    //Set-field lambda-helper-function.
    auto set_field_ = [](accel_value_type& f, const buffer_type& b, buffer_type::size_type p) -> bool {
        //Defensive coding style.
        if (b.empty() || p > b.size()-2) return false;
        //Assumes data is right-justified. Capture into a temporary integer.
        int16_t temp_ = static_cast<int16_t>(b[p]|(b[p+1]<<8));
        //Then into the field.
        f = static_cast<accel_value_type>(temp_);
        return true;
    //Set the fields with the raw data.
    //pos_datax, y, z defined as 0x0, 0x2, and 0x4, respectively
    set_field_(data.m_x, buffer, pos::pos_datax);
    set_field_(data.m_y, buffer, pos::pos_datay);
    set_field_(data.m_z, buffer, pos::pos_dataz);
    //Then return with the data.
    return data;
Neverminding the lambda-functional-programming style, does this look about right?
Reading the data-sheet and application node, is there anything special I need to do to comprehend the dynamic range? That is, whether it is configured for 2, 4, 8, or 16 g resolution?
I am assuming a right-justified field with sign extension.
Thank ye...
