uClinux-2008R1 and rootfs.jffs2
Question asked by vrp on Sep 9, 2013
Latest reply on Sep 9, 2013 by Aaronwu
I try to configure uClinux-2008R1 with rootfs.jffs2 for serial NOR flash.
I configure the system:
In file arch/blackfin/mach-bf537/boards/stamp.c:
static struct mtd_partition bfin_spi_flash_partitions[] = {
        .name = "bootloader",
        .size = 0x00040000,
        .offset = 0,
        .mask_flags = MTD_CAP_ROM
        .name = "kernel",
        .size = 0x100000,
        .offset = 0x40000
        .name = "file system",
        .size = 0x6c0000,
        .offset = 0x00140000,
kernel configuration
  Device Drivers  --->
    Memory Technology Devices (MTD)  --->
      <*> Memory Technology Device (MTD) support
      [*]   Direct char device access to MTD devices
      [*]   Caching block device access to MTD devices
    Mapping drivers for chip access  --->
      [*] Support non-linear mappings of flash chips
      < > Generic uClinux RAM/ROM filesystem support (disable this option)
    Self-contained MTD device drivers  --->
      <*> Support most SPI Flash chips (AT26DF, M25P, W25X, ...)
      <*> Support for M25 SPI Flash
    [*]   Use FAST_READ OPCode allowing SPI CLK <= 50MHz (NEW)
  File systems  --->
    Miscellaneous filesystems  --->
      <*> Journalling Flash File System v2 (JFFS2) support
In vendor/user configuration menu
  Flash Tools  --->
    [*] mtd-utils
    [*]   eraseall
    [*]   mkfs.jff2
After compiling the kernel I load vmImage and rootfs.jffs2 into BF537
tftp 0x1000000 vmImage
eeprom write 0x1000000 0x40000 $(filesize)
tftpboot 0x1000000 rootfs.jffs2
eeprom write 0x1000000 0x140000 $(filesize)
args1=setenv bootargs root=/dev/mtdblock2 rw rootfstype=jffs2
args2=setenv norboot 'eeprom read 0x1000000 0x40000 0x100000;bootm 0x1000000'
bootcmd=run args1;run args2;run norboot
Executing the command `boot` I see this:
m25p80 spi0.1: m25p64 (8192 Kbytes)
Creating 3 MTD partitions on "m25p80":
0x00000000-0x00040000 : "bootloader"
0x00040000-0x00140000 : "kernel"
0x00140000-0x00800000 : "file system"
bfin-spi bfin-spi.0: Blackfin BF5xx on-chip SPI Contoller Driver, Version 1.0, regs_base@ffc00500, dma channel@7
rtc-bfin rtc-bfin: rtc core: registered rtc-bfin as rtc0
TCP cubic registered
NET: Registered protocol family 1
rtc-bfin rtc-bfin: setting the system clock to 2009-08-28 13:40:00 (1251466800)
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003ad18c: 0xcdfa instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003ad190: 0xfd4f instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003ad194: 0xbad6 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003ad198: 0x568a instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003ad19c: 0x9ffa instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003ad1a0: 0x0297 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003ad1a4: 0x2717 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003ad1a8: 0x9ec6 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003ad1ac: 0xe864 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x003ad1b0: 0xc99b instead
Further such events for this erase block will not be printed
VFS: Mounted root (jffs2 filesystem).
Freeing unused kernel memory: 108k freed
dma_alloc_init: dma_page @ 0x00169000 - 256 pages at 0x01f00000
Have a lot of fun...
BusyBox v1.4.1 (2013-09-09 10:40:38 MSK) Built-in shell (msh)
Enter 'help' for a list of built-in commands.
root:/> JFFS2 warning: (82) jffs2_do_read_inode_internal: Truncating ino #244 to 244164 bytes failed because it only had 237568 bytes to start with!
JFFS2 warning: (82) jffs2_do_read_inode_internal: Truncating ino #261 to 320552 bytes failed because it only had 233472 bytes to start with!
JFFS2 warning: (82) jffs2_do_read_inode_internal: Truncating ino #320 to 76260 bytes failed because it only had 45056 bytes to start with!
root:/>
Help me please to make right steps.
