BF548 - Save array to file
Question asked by DarkLantern on May 20, 2010
Latest reply on May 21, 2010 by gyi
      I am beginning to work with ADSP-BF548 and I want to know if there is some easy way to send some processed data to the computer. I have created my code as a modification of Audio_test example to generate sine wave through the output of AD1980 codec and also to measure some signal on his input.  Both signals are stored in the arrays of Integer. Everything works fine, but I want to save samples of the incoming signal to the PC. Is there some easy way to do this without using another device driver? I have tried BTC for plotting those data, but this doesn't work for me (It only said that DSP program doesn't support BTC).
Thank you for your help.
My code is in the attachment.
