BF548 - Reinitialize File System Service (FSS)
Question asked by MichaelD on May 19, 2010
Latest reply on Oct 22, 2012 by MartinK
I need to reinitialize the File System Service during runtime of my application.
I'have tried to handle this with the function ReInitFileSystem() as follows:
#include <services/services.h>
#include <services/fss/adi_fss.h>
#include <stdio.h>
/* File Sytem Drivers
/* FAT12/16/32 FSD driver */
/* instruct the compiler to include code for FSD def from the header.
 * comment out the following line and add your own configuration if
 * required */
#define _ADI_FAT_DEFAULT_DEF_
#include <drivers/fsd/fat/adi_fat.h>
/* Physical Interface Device Drivers
/* ATAPI PID Driver */
/* instruct the compiler to include code for PID def from the header.
 * required */
#define _ADI_ATAPI_DEFAULT_DEF_
#include <drivers/pid/atapi/adi_atapi.h>
/* DMA and Device Manager Handles */
#include "adi_ssl_init.h"
/* Heap header */
#include <heapinfo.h>
/* DCB queue handle */
extern ADI_DCB_HANDLE adi_dcb_QueueHandle;
/* FSS General Heap Defined on a page boundary in the LDF
extern "asm" int FssGeneralHeap;
extern "asm" int FssGeneralHeap_length;
* InitFileSystem
*       Initializes the File System Service for use and adds it to the
*       C runtime extensible I/O table to make it the default for
*       the standard C I/O functions.
u32 InitFileSystem(void)
    u32 Result;
    static int initialized = 0;
    static int GeneralHeapID = 0;
    * Customized heaps for General, fat and atapi 'cache' type data
    if (!initialized)
         GeneralHeapID = heap_install (&FssGeneralHeap, (size_t)&FssGeneralHeap_length, 1);
    ADI_DEV_CMD_VALUE_PAIR ATAPI_ConfigTable [] = {
             { ADI_PID_CMD_SET_NUMBER_DEVICES, (void*)2 },
             { ADI_DEV_CMD_END, NULL },
    ADI_ATAPI_Def.pConfigTable = ATAPI_ConfigTable;
    * Configuration table to initialize the FSS
    ADI_FSS_CMD_VALUE_PAIR adi_fss_Config[] = {
        /* Set up File Cache Size */
        { ADI_FSS_CMD_SET_NUMBER_CACHE_BLOCKS,  (void*)2 },
        //{ ADI_FSS_CMD_SET_NUMBER_CACHE_BLOCKS,  (void*)8 },
        /* Set up Heap Index of the FSS General Heap */
        { ADI_FSS_CMD_SET_GENERAL_HEAP_ID,      (void*)GeneralHeapID },
        /* Register the ATA/ATAPI interface driver */
        { ADI_FSS_CMD_ADD_DRIVER,               (void*)&ADI_ATAPI_Def },
        /* Register the FAT File System driver */
        { ADI_FSS_CMD_ADD_DRIVER,               (void*)&ADI_FAT_Def },
        /* Assign the DMA Manager Handle */
        { ADI_FSS_CMD_SET_DMA_MGR_HANDLE,       (void*)adi_dma_ManagerHandle },
        /* Assign the Device Manager Handle */
        { ADI_FSS_CMD_SET_DEV_MGR_HANDLE,       (void*)adi_dev_ManagerHandle },
        /* Assign the DCB Queue Handle */
        { ADI_FSS_CMD_SET_DCB_MGR_HANDLE,       (void*)adi_dcb_QueueHandle },
        /* Command Table Terminator */
        { ADI_FSS_CMD_END, (void*)NULL }
    /* Initialize the file system service */
    Result = adi_fss_Init ( adi_fss_Config );
    /* Add to C runtime device table - which will make it the default - so we
       can use fopen(), fread(), ..., to access files on the Hard disk
    if (!Result && !initialized) {
        Result = add_devtab_entry( &adi_fss_entry );
    initialized = 1;
    // add_devtab_entry returns negative error code or device ID
    return (Result > 0) ? 0 : Result;
* ReInitFileSystem
*       Terminates and reinitializes File System Service
u32 ReInitFileSystem(void) {
     u32 Result = adi_fss_Terminate();
     printf("Res: %u\n", Result);
     WaitMilliSec(500);
     return InitFileSystem();
But after calling ReInitFileSystem() I am not longer able to access my harddisk, so is there something I have to follow in addition to terminate/reinitialize FSS correctly?
Michael
