BF561 PPI via DMA Spurious Interrupt
Question asked by scaine on May 19, 2010
Latest reply on Jul 15, 2010 by scaine
I am using a 2D DMA on a BF561 to transfer data from an ADC connected to the PPI port into on chip memory.
I have set it to interrupt when each row is full so that I can go away and process this row while the next is collecting.
The PPI is being clocked at 4MSPS into a buffer made up of 4rows of 1024 samples (X_COUNT = 1024, Y_COUNT=4)
Occasionally I get a spurious second interrupt about 1us after the first one. This causes me problems as I then think that another buffer is ready when it is not.
Has anyone experienced this problem, I have implemented in a variety of ways and still get the same problem.
Cheers
Steve
See code extract below
Function EnablePPI
Description Initialise and enable he PPI port for DMA transfers
Passed
Return
Revisions
short EnablePPI()
int temp,i;
ppiOverrun = FALSE;
ppiRepeatInt = FALSE;
//Set up the monitoring Table
ppiCount = 0;
ppiOldest = 0;  //Index to oldest buffer
ppiNewest = 0;
for(i = 0;i<PPI_BUFF_COUNT;i++)
  ppiBufferState[i] = PPI_STATE_FREE; //Indicate buffers Free
//Set up the PPI Port
*pPPI1_CONTROL= 0x387C;
*pPPI1_DELAY = 0;
*pPPI1_COUNT = 0;
temp = *pPPI1_STATUS;
//Set up the DMA Transfers
//now setup the initial values in the registers
*pDMA1_1_Y_COUNT=PPI_BUFF_COUNT; //nBuff buffers of nWords each
*pDMA1_1_X_COUNT=PPI_BUFF_LEN;
*pDMA1_1_X_MODIFY=2; //step 2 bytes per word transferred
*pDMA1_1_Y_MODIFY=2;
*pDMA1_1_START_ADDR=ppiBuffer; //start at ppiBuffer
//now set the config register...but don't start it yet
*pDMA1_1_CONFIG=0x10D6; //small descriptor list, 2 words long, interrupt after
// Set up PPI1 interrupts on IVG8....see page 4-26 in hardware manual
*pILAT |= EVT_IVG8; // clear pending IVG8 interrupts
*pSIC_IAR0 = Peripheral_IVG(12,8);
ssync();
// all interrupts are on level 8...clear all sources
//enable PPI1 interrupt sources
*pSIC_IMASK0 |= SIC_MASK(12);
//and register (also enables) handler
register_handler(ik_ivg8, PPI1_ISR);
*pDMA1_1_CONFIG |= 1; //Enable the DMA
    *pPPI1_CONTROL |= 1; //Enable the PPI Port
return SUCCESS;
Function DisablePPI
Description Disables the PPI transfers and free's relevent resources
Passed
Return
Revisions
void DisablePPI()
*pPPI1_CONTROL &= ~1; //Disable the PPI
*pDMA1_1_CONFIG &= ~1; //Disable the DMA
Function PPI1_ISR
Description The interrupt handler for the PPI port
Passed
Return
Revisions
EX_INTERRUPT_HANDLER(PPI1_ISR)
ppiBufferState[ppiNewest] = PPI_STATE_READY;
//Now update the index
ppiNewest++;
if(ppiNewest >= PPI_BUFF_COUNT)
  ppiNewest = 0;
if(PPI_STATE_FREE != ppiBufferState[ppiNewest])
  SetProcessIndicator(PROCESS_PPI_ERROR);
  ppiOverrun = TRUE;
ppiBufferState[ppiNewest] = PPI_STATE_ACQUIRING;
*pDMA1_1_IRQ_STATUS |= 3; //dismiss interrupt
// *pILAT |= EVT_IVG8;
ppiCount ++;
