Fmcomms1 quick start guide for zedboard issues?
Question asked by PedroMartos on Aug 23, 2013
Latest reply on Aug 26, 2013 by PedroMartos
I have a zedboard + fmcomms1 daughter board. I am trying the quick start guide for zed board AD-FMCOMMS1-EBZ ZYNQ QUICK START GUIDE (http://wiki.analog.com/resources/eval/user-guides/ad-fmcomms1-ebz/quickstart/zynq) but I am facing some troubles:
I downloaded the image, checked the MD5 sum before and after decompression and I did the process in windows and linux with no luck in any case. I also used two different 8GB cards and one 16 GB card with two different usb card readers.
During the boot the first message is a bad CRC (line 8). Maybe I can ignore it because is the first boot.
Then in the middle of the boot process (after mounting the filesystem), there are file not found errors and a deadlock message in the "osc" application (those messages don't appear in the web page example).
Finally I must wait for about 2 minutes for the prompt. I don't have video in the monitor and when I access the network oscilloscope from a browser, if I select an input, there is a message about "can't open xxx Device".
I am sending the console output from the UART. I would appreciate any help about this.
best regards,
Pedro
Console output:
U-Boot 2012.10 (Mar 22 2013 - 14:07:04)
DRAM:  512 MiB
WARNING: Caches not enabled
MMC:   SDHCI: 0
SF: Detected S25FL256S with page size 64 KiB, total 32 MiB
SF: Warning - Only lower 16MB is accessible in 3 byte addressing mode
*** Warning - bad CRC, using default environment               <<----------------------------------- Bad CRC?
In:    serial
Out:   serial
Err:   serial
Net:   zynq_gem
Hit any key to stop autoboot:  0
Copying Linux from SD to RAM...
Device: SDHCI
Manufacturer ID: 27
OEM: 5048
Tran Speed: 50000000
Rd Block Len: 512
SD version 2.0
High Capacity: Yes
Capacity: 14.9 GiB
Bus Width: 4-bit
reading uImage
2676384 bytes read
reading devicetree.dtb
11868 bytes read
reading uramdisk.image.gz
** Unable to read "uramdisk.image.gz" from mmc 0:1 **
## Booting kernel from Legacy Image at 03000000 ...
   Image Name:   Linux-3.6.0-00542-g1b243ba
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    2676320 Bytes = 2.6 MiB
   Load Address: 00008000
   Entry Point:  00008000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 02a00000
   Booting using the fdt blob at 0x02a00000
   Loading Kernel Image ... OK
OK
   Loading Device Tree to 1fb4e000, end 1fb53e5b ... OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Booting Linux on physical CPU 0
Linux version 3.6.0-00542-g1b243ba (lars@lars-adi-laptop) (gcc version 4.5.1 (So
urcery G++ Lite 2010.09-62) ) #6272 SMP PREEMPT Fri Apr 19 15:03:31 CEST 2013
CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=18c5387d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: Xilinx Zynq Platform, model: Xilinx Zynq ZC702
bootconsole [earlycon0] enabled
cma: CMA: reserved 40 MiB at 1d000000
Memory policy: ECC disabled, Data cache writealloc
PERCPU: Embedded 7 pages/cpu @c0e5e000 s7872 r8192 d12608 u32768
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 130048
Kernel command line: console=ttyPS0,115200 root=/dev/mmcblk0p2 rw earlyprintk ro
otfstype=ext4 rootwait devtmpfs.mount=0
PID hash table entries: 2048 (order: 1, 8192 bytes)
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 512MB = 512MB total
Memory: 468028k/468028k available, 56260k reserved, 0K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    vmalloc : 0xe0800000 - 0xff000000   ( 488 MB)
    lowmem  : 0xc0000000 - 0xe0000000   ( 512 MB)
    pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    modules : 0xbf000000 - 0xbfe00000   (  14 MB)
      .text : 0xc0008000 - 0xc04d16dc   (4902 kB)
      .init : 0xc04d2000 - 0xc04f9ec0   ( 160 kB)
      .data : 0xc04fa000 - 0xc054a720   ( 322 kB)
       .bss : 0xc054a744 - 0xc0a51810   (5149 kB)
Preemptible hierarchical RCU implementation.
        RCU lockdep checking is enabled.
        Dump stacks of tasks blocking RCU-preempt GP.
        RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
NR_IRQS:512
MIO pin 11 not assigned(00001760)
xslcr mapped to e0802000
Zynq clock init
timer #0 at e0804000, irq=43
sched_clock: 32 bits at 100 Hz, resolution 10000000ns, wraps every 4294967286ms
Console: colour dummy device 80x30
Lock dependency validator: Copyright (c) 2006 Red Hat, Inc., Ingo Molnar
... MAX_LOCKDEP_SUBCLASSES:  8
... MAX_LOCK_DEPTH:          48
... MAX_LOCKDEP_KEYS:        8191
... CLASSHASH_SIZE:          4096
... MAX_LOCKDEP_ENTRIES:     16384
... MAX_LOCKDEP_CHAINS:      32768
... CHAINHASH_SIZE:          16384
memory used by lock dependency info: 3695 kB
per task-struct memory footprint: 1152 bytes
Calibrating delay loop... 1332.01 BogoMIPS (lpj=6660096)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
Setting up static identity map for 0x365970 - 0x3659a4
L310 cache controller enabled
l2x0: 8 ways, CACHE_ID 0x410000c8, AUX_CTRL 0x72360000, Cache size: 524288 B
CPU1: Booted secondary processor
CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
Brought up 2 CPUs
SMP: Total of 2 processors activated (2664.03 BogoMIPS).
devtmpfs: initialized
NET: Registered protocol family 16
DMA: preallocated 256 KiB pool for atomic coherent allocations
xgpiops e000a000.gpio: gpio at 0xe000a000 mapped to 0xe080c000
hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 4 bytes.
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
Advanced Linux Sound Architecture Driver Version 1.0.25.
Switching to clocksource xttcps_clocksource
NET: Registered protocol family 2
TCP established hash table entries: 16384 (order: 5, 131072 bytes)
TCP bind hash table entries: 16384 (order: 7, 589824 bytes)
TCP: Hash tables configured (established 16384 bind 16384)
TCP: reno registered
UDP hash table entries: 256 (order: 2, 20480 bytes)
UDP-Lite hash table entries: 256 (order: 2, 20480 bytes)
msgmni has been set to 994
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
xuartps e0001000.uart: failed to get alias id, errno -19
e000€console [ttyPS0] enabled, bootconsole disabled
xdevcfg f8007000.devcfg: ioremap f8007000 to e0814000 with size 1000
[drm] Initialized drm 1.1.0 20060810
platform 70e00000.axi_hdmi: Driver axi-hdmi requests probe deferral
brd: module loaded
loop: module loaded
libphy: XEMACPS mii bus: probed
xemacps e000b000.eth: pdev->id -1, baseaddr 0xe000b000, irq 54
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ULPI transceiver vendor/product ID 0x0451/0x1507
Found TI TUSB1210 ULPI transceiver.
ULPI integrity check: passed.
xusbps-ehci xusbps-ehci.0: Xilinx PS USB EHCI Host Controller
xusbps-ehci xusbps-ehci.0: new USB bus registered, assigned bus number 1
xusbps-ehci xusbps-ehci.0: irq 53, io mem 0x00000000
xusbps-ehci xusbps-ehci.0: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
mousedev: PS/2 mouse device common for all mice
i2c /dev entries driver
at24 1-0050: 256 byte 24c02 EEPROM, writable, 1 bytes/write
at24 1-0054: 256 byte 24c02 EEPROM, writable, 1 bytes/write
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
mmc0: Invalid maximum block size, assuming 512 bytes
mmc0: SDHCI controller on e0100000.sdhci [e0100000.sdhci] using ADMA
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
mmc0: new high speed SDHC card at address 0007
mmcblk0: mmc0:0007 SD16G 14.9 GiB
cf_axi_adc 79020000.cf-ad9643-core-lpc: Device Tree Probing 'cf-ad9643-core-lpc'
platform 79020000.cf-ad9643-core-lpc: Driver cf_axi_adc requests probe deferral
mmcblk0: p1 p2
spi spi32766.1: Driver ad9467 requests probe deferral
ad9548 spi32766.2: Rev. 0xC6 probed
ad9523 spi32766.3: probed ad9523-lpc
cf_axi_dds 74200000.cf-ad9122-core-lpc: Device Tree Probing 'cf-ad9122-core-lpc'
platform 74200000.cf-ad9122-core-lpc: Driver cf_axi_dds requests probe deferral
adv7511 0-0039: Failed to add route AIFIN->TMDS
adv7511-hdmi-snd adv7511_hdmi_snd.4:  adv7511 <-> 75c00000.axi-spdif-tx mapping
ok
TCP: cubic registered
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
Registering SWP/SWPB emulation handler
drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
ALSA device list:
  #0: HDMI monitor
No connectors reported connected with modes
[drm] Cannot find any crtc or sizes - going 1024x768
Console: switching to colour frame buffer device 128x48
fb0:  frame buffer device
drm: registered panic notifier
[drm] Initialized axi_hdmi_drm 1.0.0 20120930 on minor 0
EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
VFS: Mounted root (ext4 filesystem) on device 179:2.
Freeing init memory: 156K
ào|oo DCI 1ahead main process (754) terminated with status 5
cf_axi_dds 74200000.cf-ad9122-core-lpc: Analog Devices CF_AXI_DDS_DDS MASTER (0x
10063) at 0x74200000 mapped to 0xe08e0000, probed DDS AD9122
ooo|oo---------------------------  DCO 0x82 CLK 245760000 Hz
cf_axi_adc 79020000.cf-ad9643-core-lpc: ADI AIM (0x10063) at 0x79020000 mapped t
o 0xe0900000, DMA-0 probed ADC AD9643 as MASTER
chmod: cannot access `/sys/bus/iio/devices/iio:device*/trigger/*': No such file        <<-------------- File not found errors?
or directory
chmod: cannot access `/sys/bus/iio/devices/trigger*/*': No such file or director
y
chmod: cannot access `/sys/bus/platform/devices/*.axi-jesd204b-rx4/*': No such f
ile or directory
[ INFO: possible circular locking dependency detected ]                                         <<---------- Deadlock issue?
3.6.0-00542-g1b243ba #6272 Not tainted
osc/2099 is trying to acquire lock:
(prepare_lock){+.+.+.}, at: [<c0288e48>] clk_get_rate+0x18/0x38
but task is already holding lock:
(&dev->mlock){+.+...}, at: [<c02967e8>] cf_axi_dds_read_raw+0x38/0x224
which lock already depends on the new lock.
the existing dependency chain (in reverse order) is:
-> #1 (&dev->mlock){+.+...}:
       [<c005c8b0>] lock_acquire+0x60/0x74
       [<c0362eb8>] mutex_lock_nested+0x44/0x3a0
       [<c02955c0>] ad9523_read_raw+0x28/0x10c
       [<c0295d10>] ad9523_clk_recalc_rate+0x30/0x40
       [<c0289768>] __clk_init+0x294/0x3a8
       [<c0289978>] _clk_register+0xfc/0x14c
       [<c0289a7c>] clk_register+0x4c/0x74
       [<c0295d9c>] ad9523_clk_register+0x7c/0x94
       [<c035c89c>] ad9523_probe+0xb34/0xd28
       [<c020470c>] spi_drv_probe+0x4c/0x5c
       [<c01c9aac>] driver_probe_device+0xb4/0x1ec
       [<c01c9c4c>] __driver_attach+0x68/0x8c
       [<c01c84b0>] bus_for_each_dev+0x48/0x74
       [<c01c9220>] bus_add_driver+0x98/0x218
       [<c01ca0c8>] driver_register+0x9c/0x12c
       [<c0008624>] do_one_initcall+0x94/0x168
       [<c04d28e0>] kernel_init+0xf8/0x1c4
       [<c000e4c0>] kernel_thread_exit+0x0/0x8
-> #0 (prepare_lock){+.+.+.}:
       [<c005bc74>] __lock_acquire+0x1244/0x19c0
       [<c02969a0>] cf_axi_dds_read_raw+0x1f0/0x224
       [<c028c070>] iio_read_channel_info+0x30/0x218
       [<c01c696c>] dev_attr_show+0x20/0x44
       [<c00fed64>] sysfs_read_file+0xb0/0x124
       [<c00aded8>] vfs_read+0xac/0x134
       [<c00adf9c>] sys_read+0x3c/0x68
       [<c000d9c0>] ret_fast_syscall+0x0/0x3c
other info that might help us debug this:
Possible unsafe locking scenario:
       CPU0                    CPU1
  lock(&dev->mlock);
                               lock(prepare_lock);
                               lock(&dev->mlock);
  lock(prepare_lock);
*** DEADLOCK ***
3 locks held by osc/2099:
#0:  (&buffer->mutex){+.+.+.}, at: [<c00fecdc>] sysfs_read_file+0x28/0x124
#1:  (s_active#29){.+.+.+}, at: [<c00fed38>] sysfs_read_file+0x84/0x124
#2:  (&dev->mlock){+.+...}, at: [<c02967e8>] cf_axi_dds_read_raw+0x38/0x224
stack backtrace:
[<c001355c>] (unwind_backtrace+0x0/0xe0) from [<c0059414>] (print_circular_bug+0
x274/0x2c0)
[<c0059414>] (print_circular_bug+0x274/0x2c0) from [<c005bc74>] (__lock_acquire+
0x1244/0x19c0)
[<c005bc74>] (__lock_acquire+0x1244/0x19c0) from [<c005c8b0>] (lock_acquire+0x60
/0x74)
[<c005c8b0>] (lock_acquire+0x60/0x74) from [<c0362eb8>] (mutex_lock_nested+0x44/
0x3a0)
[<c0362eb8>] (mutex_lock_nested+0x44/0x3a0) from [<c0288e48>] (clk_get_rate+0x18
/0x38)
[<c0288e48>] (clk_get_rate+0x18/0x38) from [<c02969a0>] (cf_axi_dds_read_raw+0x1
f0/0x224)
[<c02969a0>] (cf_axi_dds_read_raw+0x1f0/0x224) from [<c028c070>] (iio_read_chann
el_info+0x30/0x218)
[<c028c070>] (iio_read_channel_info+0x30/0x218) from [<c01c696c>] (dev_attr_show
+0x20/0x44)
[<c01c696c>] (dev_attr_show+0x20/0x44) from [<c00fed64>] (sysfs_read_file+0xb0/0
x124)
[<c00fed64>] (sysfs_read_file+0xb0/0x124) from [<c00aded8>] (vfs_read+0xac/0x134
[<c00aded8>] (vfs_read+0xac/0x134) from [<c00adf9c>] (sys_read+0x3c/0x68)
[<c00adf9c>] (sys_read+0x3c/0x68) from [<c000d9c0>] (ret_fast_syscall+0x0/0x3c)
Login timed out after 60 seconds.
init: auto-serial-console main process ended, respawning
Last login: Thu Jan  1 00:00:11 UTC 1970 on tty1
init: openvt main process ended, respawning
Welcome to Linaro 12.10 (GNU/Linux 3.6.0-00542-g1b243ba armv7l)
* Documentation:  https://wiki.linaro.org/
271 packages can be updated.
125 updates are security updates.
root@linaro-ubuntu-desktop:~#                  <------ Finally I get a login in the console, but no video in the dvi output
