Reinitializing PPI interface to use a different width (BF527)
Question asked by tcmichals on Aug 21, 2013
Latest reply on Sep 12, 2013 by tcmichals
All,
There is a requirement to reset the PPI Element count depending the incoming data rate.   The issue I'm trying to understand is how clear/reset/recover the DMA buffers made by adi_dev_Read.    The  pseudo code below shows a for loop calling adi_dev_Read allowing DMA to have several buffers to compensate for software jitter.  The basic goal is to:
  1. Setup PPI basic one time initialization
  2. Setup PPI for a given element count
  3. Start PPI Data collection
  4. Stop PPI
  5. goto step 2
openPPI()
    eResult = adi_dev_Open(adi_dev_ManagerHandle,
                           /* PPI Entry point */
                           &ADIPPIEntryPoint,
                           0,
                           this,
                           &m_hPpiDevice,
                           ADI_DEV_DIRECTION_INBOUND,
                           adi_dma_ManagerHandle,
                           adi_DCBManagerHandle /*Working NULL */,
                           adi_dd_VCCD_PpiCallback);
restartPPI( elementCount)
ADI_PPI_CONTROL_REG ppi_control;
    u16 ppi_count = ( u16)((width-1) &0xFFFF);
    // Configure the PPI_CONTROL register
    ppi_control.port_en  = 0;    // Disable until ready
    ppi_control.port_dir = 0;    // Receive mode
    ppi_control.xfr_type = 3;    // Non ITU-R 656 mode
    ppi_control.port_cfg = 0;    // 1 external frame syncs
    ppi_control.fld_sel  = 0;    // ????
    ppi_control.skip_en  = 0;    // Not required
    ppi_control.skip_eo  = 0;    // Not required
    ppi_control.pack_en  = 0;    // Not required
    ppi_control.dlen     = 7;    // 16 Bits data length
    ppi_control.polc     = 0;    // Do not invert PPI_CLK
    ppi_control.pols     = 0;    // Do not invert PPI_FS1 & PPI_FS2
// table of configuration values for the PPI on input
    ADI_DEV_CMD_VALUE_PAIR InboundConfigurationTable [] = {
        { ADI_DEV_CMD_SET_DATAFLOW_METHOD,      (void *)ADI_DEV_MODE_CHAINED},
        { ADI_PPI_CMD_SET_CONTROL_REG,          (void*)(*(u16*)&ppi_control)},
        { ADI_PPI_CMD_SET_TRANSFER_COUNT_REG,   (void*)(*(u16*)&ppi_count)},
        {ADI_DEV_CMD_SET_ERROR_REPORTING, (void*)TRUE},
        {ADI_DEV_CMD_SET_STREAMING,(void *)TRUE},
        { ADI_DEV_CMD_END,                       NULL},
//STOP PPI
Result = adi_dev_Control(m_hPpiDevice, ADI_DEV_CMD_SET_DATAFLOW, (void *)FALSE);
Result = adi_dev_Control( m_hPpiDevice, ADI_DEV_CMD_TABLE, (void*)InboundConfigurationTable );
for ( i=0; i < MAX_DESC_VCCD; ++i )
        m_rxCCDDesc[i].Data = (void *)&_ppiData[i][0];
        m_rxCCDDesc[i].ElementWidth = 2 ;
        m_rxCCDDesc[i].ElementCount = width ; //1D
        m_rxCCDDesc[i].CallbackParameter= (void *)&m_rxCCDDesc[i];
        m_rxCCDDesc[i].pNext = (adi_dev_1d_buffer *)NULL;
        m_rxCCDDesc[i].pAdditionalInfo = (void *) this;
FlushInvArea(m_rxCCDDesc[i].Data, ((char *)m_rxCCDDesc[i].Data) +
                     (m_rxCCDDesc[i].ElementWidth * m_rxCCDDesc[i].ElementCount)
        /* submit transfer buffers to PPI driver */
        if ( (Result = adi_dev_Read(m_hPpiDevice,
                                    //ADI_DEV_2D,
                                    ADI_DEV_1D,
                                    (ADI_DEV_BUFFER *)&m_rxCCDDesc[i]))
             != 0 )
            syslog(LOG_DEBUG,SYSLOG_MODULE_VCCD, "adi_dev_Write failed. Error code: 0x%08X\n", Result);
  Result = adi_dev_Control(m_hPpiDevice, ADI_DEV_CMD_SET_DATAFLOW, (void *)TRUE);
     return rc;
