Suggestion for a Low noise differential input / single ended 75 ohm output Amplifier?
Question asked by Frank-Hertel on Aug 20, 2013
Latest reply on Aug 21, 2013 by Frank-Hertel
What would you recommend?-----
I am in need of a Low noise differential input/ single ended output amp to cover approx 100 KHZ thru 10 MHZ (a higher shelf freq. is ok).  The driving source will be  Shielded, Single Turn LOOP Antenna.  Input balance is important.  Noise figure of the amp is extremely important.  The gain needs to be no more than 20 DBv (x10).
Thank you!
Frank Hertel
