Siva23
ADE7878 Chip SPI communication
Discussion created by Siva23 on Aug 13, 2013
Latest reply on Aug 19, 2013 by hmani
image: Inline image 2[image: Inline image 1]
Please find attached plots from oscilloscope. I tried to perform
communication using SPI protocol between TS7800 Micro controller and
ADE7878 chip. It says that on power up, the SS signal has to toggled from
high to low thrice and then a write operation has to be performed on
CONFIG2 register to lock to SPI mode.
In the attached plot that is shown above, I try to perform a write
operation using ADE7878 CONFIG2 register and then reading the same value
from the register after toggling SS pin thrice. How would I know that SPI
port is set up for communication?
I also see that the MISO output runs low only during read operation and is
high during write operation. (MISO output not in the figure)
The plot shows SS signal and the SCLK signal. In the duration during which
the SS pin runs low, the clock goes low for 40 micro seconds  while
performing read operation and on the other hand, sometimes, I dont observe
clock at all during the write operation. Sometimes, I observe a clock that
goes low for 12 micro seconds. So I have attached both the plots. Any
suggestions if I could try anything else using ADE7878 chip and micro
controller TS7800.
P.S. For some reason, I am not able to login directly to the Engineer Zone
help even after giving the right username and password.
Thanks for the help.
Sivaramakrishnan C N Iyer
