SPI Flash parameters for U-boot
Question asked by GatsbyDSP on Aug 12, 2013
Latest reply on Aug 12, 2013 by Aaronwu
I'm having a few issues getting u-boot to work correctly on my custom BF537 with:
- SDRAM IS42S16400E (8MB)
- SPI Flash chip SST25VF032B (4MB)
I know the SPI flash chip is supported already and I'm following this document.http://docs.blackfin.uclinux.org/doku.php?id=bootloaders:u-boot:porting#board_directory  and I'm also using this to try and get u-boot to boot from flash. http://blackfin.uclinux.org/doku.php?id=bootloaders:u-boot:serial-flash
I am able to boot the latest u-boot from UART but I've not yet managed to get u-boot to boot directly from SPI flash. I believe the main issue is that I have not edited my board configuration file (include/configs/bf537-custom.h) file correctly. I've started with the bf537-stamp.h and edited it to suit my custom configuration.
Memory Settings:
#define CONFIG_MEM_ADD_WDTH 7
#define CONFIG_MEM_SIZE 8
#define CONFIG_EBIU_SDRRC_VAL 0x8B0     /*Most of this calculated using the spreadsheet*/
#define CONFIG_EBIU_SDGCTL_VAL 0x809199C9
#define CONFIG_EBIU_SDBCTL_VAL 0x1
#define CONFIG_EBIU_AMGCTL_VAL 0xFF
#define CONFIG_EBIU_AMBCTL0_VAL 0x7BB07BB0
#define CONFIG_EBIU_AMBCTL1_VAL 0xFFC27BB0
#define CONFIG_SYS_MONITOR_LEN (512 * 1024)     /*No idea what this*/
#define CONFIG_SYS_MALLOC_LEN (384 * 1024)     /*No idea what this*/
* Flash Settings
#define CONFIG_FLASH_CFI_DRIVER
#define CONFIG_SYS_FLASH_BASE                    0x20000000
#define CONFIG_SYS_FLASH_CFI
#define CONFIG_SYS_FLASH_PROTECTION
#define CONFIG_SYS_MAX_FLASH_BANKS          1
#define CONFIG_SYS_MAX_FLASH_SECT          1024 /*128 or 1024*/
/* I don't know how many blocks the SST25VF032B has */
How do I calculate the number of blocks or sectors? I'm guessing here.
* SPI Settings
#define CONFIG_BFIN_SPI           1
#define CONFIG_ENV_SPI_MAX_HZ          20000000
#define CONFIG_SF_DEFAULT_SPEED          20000000
Not sure about the speed. The datasheet specifies 18MHz but I think this is something different.
#define CONFIG_SPI_FLASH          1
#define CONFIG_SPI_FLASH_ALL
#define CONFIG_CMD_SF
#define CONFIG_SF_DEFAULT_MODE                     SPI_MODE_3
/*#define CONFIG_ENV_IS_IN_SPI_FLASH                    1*/
#define CONFIG_ENV_SPI_MODE                    SPI_MODE_3
#define CONFIG_ENV_SPI_BUS                    0
#define CONFIG_ENV_SPI_CS                    1
#define CONFIG_SPI_FLASH_SST
* Env Storage Settings
#if (CONFIG_BFIN_BOOT_MODE == BFIN_BOOT_SPI_MASTER)
#define CONFIG_ENV_OFFSET          0x10000
#define CONFIG_ENV_SIZE                    0x2000
#define CONFIG_ENV_SECT_SIZE          0x10000
#else
#define CONFIG_ENV_IS_IN_FLASH
#define CONFIG_ENV_OFFSET          0x4000
#define CONFIG_ENV_ADDR                    (CONFIG_SYS_FLASH_BASE + CONFIG_ENV_OFFSET)
#define CONFIG_ENV_SECT_SIZE          0x2000
#endif
Is there a document that explains these parameters in detail?
At the moment:
bfin> sf probe 1
SF: Detected SST25VF032B with page size 4 KiB, total 4 MiB
This does produce something useful although not like the example in the documentation:
bfin> sf probe 2
SF: Got idcode 20 20 15
2048 KiB M25P16 at 0:2 is now current device
When I give the command flinfo I get: Bank # 1: missing or unknown FLASH type
Is the flinfo command only for parallel flash?
Also, when I do a 'make' with the SPI BOOT parameter enabled, which file do I need to tftp to the board? The documentation appears to show a uImage file but this isn't created for me after compile. I do have: u-boot, .bin, .ldr, .lds, ,map, .srec
Any help is gratefully appreciated.
