bf609 expansion Board adv7511 bfin_display test
Question asked by alen on Aug 11, 2013
Latest reply on Aug 14, 2013 by Aaronwu
hi,adi's experts
     I use adv7511 the hdmi as ouput, I have configured the kernel as required, but when the compiler is completed, the system starts, and is not registered video under /dev Directory.
root:/> dmesg
Linux version 3.5.7-ADI-2012R2 (root@louie) (gcc version 4.3.5 (ADI-2012R2-RC2) ) #56 Mon Aug 12 11:19:21 CST 2013
register early platform devices
bootconsole [early_shadow0] enabled
ERROR: Not running on ADSP-BF609: unknown CPUID 0x0000 Rev 0.0
Board Memory: 128MB
Kernel Managed Memory: 124MB
Memory map:
  fixedcode = 0x00000400-0x00000490
  text      = 0x00001000-0x001b3170
  rodata    = 0x001b3194-0x0024579c
  bss       = 0x00246000-0x00259308
  data      = 0x00259320-0x00286000
    stack   = 0x00284000-0x00286000
  init      = 0x00286000-0x00ba2000
  available = 0x00ba2000-0x05c00000
  DMA Zone  = 0x05c00000-0x07c00000
Hardware Trace active and enabled
Blackfin support (C) 2004-2010 Analog Devices, Inc.
Compiled for ADSP-BF609 Rev 0.0
Blackfin Linux support by http://blackfin.uclinux.org/
Processor Speed: 500 MHz core clock, 250 MHz SCLk, 125 MHz SCLK0, 125 MHz SCLK1 and 250 MHz DCLK
boot memmap: 0000000000ba2000 - 0000000005c00000 (usable)
On node 0 totalpages: 23552
free_area_init_node: node 0, pgdat 00282a58, node_mem_map 00ba4000
  DMA zone: 184 pages used for memmap
  DMA zone: 0 pages reserved
  DMA zone: 23368 pages, LIFO batch:0
NOMPU: setting up cplb tables
Instruction Cache Enabled for CPU0
  External memory: cacheable in instruction cache
  L2 SRAM        : uncacheable in instruction cache
Data Cache Enabled for CPU0
  External memory: cacheable (write-through) in data cache
  L2 SRAM        : uncacheable in data cache
pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
pcpu-alloc: [0] 0
Built 1 zonelists in Zone order, mobility grouping off.  Total pages: 23368
Kernel command line: root=/dev/mtdblock0 rw clkin_hz=25000000 earlyprintk=serial ,uart0,57600 console=ttyBF0,57600 mem=124M max_mem=128M icc_l2_mem=0x8000
PID hash table entries: 512 (order: -1, 2048 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Kernel managed physical pages: 23552
Memory available: 81384k/126976k RAM, (9328k init code, 1736k kernel code, 844k data, 32768k dma, 916k reserved)
NR_IRQS:291
Configuring Blackfin Priority Driven Interrupts
Console: colour dummy device 80x25
console [ttyBF0] enabled, bootconsole disabled
Calibrating delay loop... 995.32 BogoMIPS (lpj=1990656)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
devtmpfs: initialized
Blackfin Scratchpad data SRAM: 4 KB
Blackfin L1 Data A SRAM: 16 KB (9 KB free)
Blackfin L1 Data B SRAM: 32 KB (32 KB free)
Blackfin L1 Instruction SRAM: 64 KB (50 KB free)
Blackfin L2 SRAM: 256 KB (224 KB free)
NET: Registered protocol family 16
Blackfin DMA Controller
ezkit_init(): registering device resources
ezkit_init(): request emac pins failed
bio: create slab <bio-0> at 0
SCSI subsystem initialized
bfin-spi bfin-spi.0: master is unqueued, this is deprecated
bfin-spi bfin-spi.0: bfin-spi probe success
bfin-spi bfin-spi.1: master is unqueued, this is deprecated
bfin-spi bfin-spi.1: bfin-spi probe success
i2c-bfin-twi i2c-bfin-twi.0: Blackfin on-chip I2C TWI Contoller, regs_base@ffc01e00
i2c-bfin-twi i2c-bfin-twi.1: Blackfin on-chip I2C TWI Contoller, regs_base@ffc01f00
Linux media interface: v0.10
Linux video capture interface: v2.00
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
PTP clock support registered
NET: Registered protocol family 23
Switching to clocksource bfin_cs_cycles
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP: reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
msgmni has been set to 158
io scheduler noop registered (default)
dma_alloc_init: dma_page @ 0x032e7000 - 8192 pages at 0x05c00000
bfin-uart: Blackfin serial driver
bfin-uart.0: ttyBF0 at MMIO 0xffc02000 (irq = 88) is a BFIN-UART
physmap platform flash device: 01000000 at b0000000
physmap-flash.0: Found 1 x16 devices at 0x0 in 16-bit bank. Manufacturer ID 0x000089 Chip ID 0x008821
Intel/Sharp Extended Query Table at 0x010A
Using buffer write method
Using auto-unlock on power-up/resume
cfi_cmdset_0001: Erase suspend on write enabled
erase region 0: offset=0x0,size=0x8000,blocks=4
erase region 1: offset=0x20000,size=0x20000,blocks=127
Creating 3 MTD partitions on "physmap-flash.0":
0x000000000000-0x000000080000 : "bootloader(nor)"
0x000000080000-0x000000480000 : "linux kernel(nor)"
0x000000480000-0x000001000000 : "file system(nor)"
m25p80 spi0.1: w25q32 (4096 Kbytes)
Creating 3 MTD partitions on "m25p80":
0x000000000000-0x000000080000 : "bootloader(spi)"
0x000000080000-0x000000200000 : "linux kernel(spi)"
0x000000200000-0x000000400000 : "file system(spi)"
CAN device driver interface
bfin_can bfin_can.0: bfin_can device registered(&reg_base=ffc00a00, rx_irq=47, tx_irq=48, err_irq=49, sclk=125000000)
        DWMAC100
No HW DMA feature register supported
Enhanced/Alternate descriptors
RX IPC Checksum Offload not configured.
stmmac_dvr_probe: warning: cannot get CSR clock
stmmac: probed
eth0: PHY ID 20005c90 at 1 IRQ 0 (stmmac-0:01) active
input: bfin-rotary as /devices/platform/bfin-rotary/input/input0
i2c /dev entries driver
lirc_dev: IR Remote Control driver registered, major 250
IR NEC protocol handler initialized
IR RC5(x) protocol handler initialized
IR RC6 protocol handler initialized
IR JVC protocol handler initialized
IR Sony protocol handler initialized
IR RC5 (streamzap) protocol handler initialized
IR SANYO protocol handler initialized
IR MCE Keyboard/mouse protocol handler initialized
IR LIRC bridge handler initialized
Hardware Trace:
   0 Target : <0x001b2e24> { _dump_stack + 0x0 }
     Source : <0x00005530> { _peripheral_request + 0x1b0 } JUMP.L
   1 Target : <0x00005522> { _peripheral_request + 0x1a2 }
     Source : <0x000054a6> { _peripheral_request + 0x126 } IF !CC JUMP pcrel
   2 Target : <0x000054a4> { _peripheral_request + 0x124 }
     Source : <0x000051c6> { _cmp_label + 0x22 } RTS
   3 Target : <0x000051c2> { _cmp_label + 0x1e }
     Source : <0xffa01944> { _strcmp + 0x14 } RTS
   4 Target : <0xffa01942> { _strcmp + 0x12 }
     Source : <0xffa0193a> { _strcmp + 0xa } IF !CC JUMP pcrel
   5 Target : <0xffa01930> { _strcmp + 0x0 }
     Source : <0x000051be> { _cmp_label + 0x1a } CALL pcrel
   6 Target : <0x000051a4> { _cmp_label + 0x0 }
     Source : <0x000054a0> { _peripheral_request + 0x120 } JUMP.L
   7 Target : <0x0000549c> { _peripheral_request + 0x11c }
     Source : <0x0000558e> { _peripheral_request + 0x20e } JUMP.S
   8 Target : <0x00005588> { _peripheral_request + 0x208 }
     Source : <0x00005470> { _peripheral_request + 0xf0 } IF CC JUMP pcrel
   9 Target : <0x0000546e> { _peripheral_request + 0xee }
     Source : <0x000053ea> { _peripheral_request + 0x6a } IF !CC JUMP pcrel
  10 Target : <0x000053a4> { _peripheral_request + 0x24 }
     Source : <0x0000539e> { _peripheral_request + 0x1e } IF CC JUMP pcrel
  11 Target : <0x0000539a> { _peripheral_request + 0x1a }
     Source : <0x0000538e> { _peripheral_request + 0xe } IF CC JUMP pcrel
  12 Target : <0x00005380> { _peripheral_request + 0x0 }
     Source : <0x000055b4> { _peripheral_request_list + 0x24 } JUMP.L
  13 Target : <0x000055b2> { _peripheral_request_list + 0x22 }
     Source : <0x000055a2> { _peripheral_request_list + 0x12 } JUMP.S
  14 Target : <0x00005590> { _peripheral_request_list + 0x0 }
     Source : <0x0012c570> { _ppi_create_instance + 0x28 } JUMP.L
  15 Target : <0x0012c560> { _ppi_create_instance + 0x18 }
     Source : <0x0012c552> { _ppi_create_instance + 0xa } IF !CC JUMP pcrel
Stack info:
SP: [0x0201fcfc] <0x0201fcfc> /* kernel dynamic memory */
FP: (0x0201fe34)
Memory from 0x0201fcf0 to 02020000
0201fcf0: 00000010  0201fcfc  00000000 [0201fd28] 0201fd28  00005534  00000000  00008200
0201fd10: 0201d30c  002631e8  0201d314  002631b4  00000001  0000ffff  0201fd58  000055b8
0201fd30: 001b3c54  036d1400  00253cac  00000000  001b3c40  0021c5f0  00000000  0201fd98
0201fd50: 000ab1d6  02009824  0201fd7c  0012c574  002610e8  00261124  001b3c40  0027d248
0201fd70: 036ca7e0  0201fe34  001b224c  0201fe34  001b2262  00261124  00261600  036ddf48
0201fd90: 0201fe0c  00000000  0201fdcc  00088342  036ddf48  002517e4  00000008  0201fdcc
0201fdb0: 000889da  0008825e  036ddf48  0201fe0c  00000000  0201fdc8  00000763  0201fe14
0201fdd0: 00088fce  0201fe0c  036ddf48  02052508  00000000  036ca7e0  0000000f  00000000
0201fdf0: 0201fdf4  00000761  0201fe30  00088b52  036ce108  036ca7e0  036ca7e0  02052508
0201fe10: 00000000  0201fe44  000890f8  002610f0  0027d248  00253cac  00000000  002610f8
0201fe30: 0027d248 (0201fe64)<000dbcf4> 002610f0  0027d248  00253cac  00261124  0201fec0
0201fe50: 0027d248  00000000  0201fe7c  000dac20  002610f0 (0201fe7c)<000dac38> 036ca7e0
0201fe70: 0027d248  0201fe88  ffa02294 (0201fea0) 000dadd8  002610f0  0027d248  036ca7e0
0201fe90: 00261124  00000000  0201fec4  000ac030 (0201fec8)<000d9a6c> 000dad74  0027d248
0201feb0: 00000000  0000003c  0201fee8  000ac962  0201c60c  02053e70 (0201fef0) 000daaee
0201fed0: 00271880  00000007  00246010  00000000  0201ff0c  0201ff08  0201ff0c  000dad74
0201fef0:(0201ff0c) 000da11e  00112500  001f9598  0201ff20  001f9598  001fd258 (0201ff38)
0201ff10: 000db2d8  002a0548  00293774  0027d248  00000007  00246010  0000003c  002a053c
0201ff30: 0201ff58  00112500 (0201ff60) 000dc03c  002a0548  00293774  00246008  00000007
0201ff50: 00246010  00000000  0201ff74  0029376e (0201ff74) 00293784  0201ff90  00000001
0201ff70: 00000000 (0201ff90)<00001106> 00000000  00000000  00000000  00000006  00000006
0201ff90:(0201ffd0) 00286266  002a0548  0029a868  0029a848  00000007  00246010  0000003c
0201ffb0: 0028610c  00215828  00000000  002453d8  0000003c  00000006  00000006  0028610c
0201ffd0:(00000000)<000015e6> 00000000  00000000  00000000  00000000  00000000  00000000
0201fff0: 00000000  00000000  ffffffff  00002806
Return addresses in stack:
   frame  1 : <0x000dbcf4> { _platform_drv_probe + 0x14 }
   frame  2 : <0x000dac38> { _driver_probe_device + 0x64 }
   frame  4 : <0x000d9a6c> { _bus_for_each_dev + 0x48 }
   frame 10 : <0x00001106> { _do_one_initcall + 0x106 }
   frame 12 : <0x000015e6> { _kernel_thread_helper + 0x6 }
peripheral_request: Peripheral 0 function 1 is already reserved by smc0 !
request peripheral failed
bfin_display: Unable to create ppi
bfin_wdt: initialized: timeout=20 sec (nowayout=0)
icc icc.0: initialized
TCP: cubic registered
can: controller area network core (rev 20090105 abi 8)
NET: Registered protocol family 29
Freeing unused kernel memory: 9328k freed
eth0: device MAC address 02:80:ad:20:31:e8
No MAC Management Counters available
PHY: stmmac-0:01 - Link is Up - 100/Full
root:/>
