application linked with shared libraries
Question asked by dbutter on Aug 7, 2013
Latest reply on Jun 4, 2014 by dbutter
For my application I need to use shared libraries on uClinux/blackfin. I have build the kernel and usespace with support for FDPIC/shared, but I cannot get a simple hello world (dynamically linked) to run. I'm using buildroot/kernel/toolchain checked out from about 1-week ago.The target is a BF537.
Here is an example:
/* testlib.c --- */
/* Code: */
#include <stdio.h>
int hello()
  printf("hello from shared library\n");
  return 0;
/* testlib.c ends here */
/* test.c --
/* Code: */
#include <stdio.h>
int hello();
int main()
  hello();
  return 0;
/* test.c ends here */
Then I build it as follows:
db@dbl:/opt/nfs$ bfin-linux-uclibc-gcc -Wall -c testlib.c
db@dbl:/opt/nfs$ bfin-linux-uclibc-gcc -Wall -o libtest.so testlib.o -shared -Wl,-soname,libtest.so
db@dbl:/opt/nfs$ bfin-linux-uclibc-gcc -Wall -c test.c
db@dbl:/opt/nfs$ bfin-linux-uclibc-gcc -o test test.o -L. -ltest
db@dbl:/opt/nfs$ bfin-linux-uclibc-ldd ./test
checking sub-depends for 'libtest.so'
checking sub-depends for 'not found'
    libtest.so => libtest.so (0x00000000)
    libgcc_s.so.1 => not found (0x00000000)
    libc.so.0 => not found (0x00000000)
    not a dynamic executable
So I made sure the referenced libraries are in a standard path (/lib) on target and run "test" on target:
root:/opt/nfs> ./test
sh: can't execute './test': No such file or directory
What am I missing here?
Thanks!
Regards, Devin
