Kilohercas
CrossCore Embedded Studio vs. VisualDSP++ Compiler Efficiency
Discussion created by Kilohercas on Aug 3, 2013
Latest reply on Aug 14, 2013 by CraigG
Branched from an earlier discussion
Just wondering, does VisualDSP++ and CrossCode have same compiler efficiency ? (or i miss some compiler options to enable)
Same code for VisualDSP++ runs at 900KHz  but compiled on CrossCode with same optimization runs just over 530KHz. Also VisualDSP++ code runs with no glitches, but CrossCode have some strange behavior
     int i = 0;
    asm("bit set FLAGS FLG1O;");
    asm("bit set FLAGS FLG0O;");
    while(i<128)
        sinusas[i]=sinf(0.4908738521f*i);
        cosinus[i]=cosf(0.4908738521f*i);
        i++;
    i=0;
    while(i<256)
        adc[i]=(int)(32767.0f+32765.0f*cosf(0.4908738521f*i));
        i++;
    while(1)
        i=0;
        real = imag = 0;
        while(i<128)
            real+=adc[i+offset]*cosinus[i];
            imag-=adc[i+offset]*sinusas[i];
            i++;
        if(Faze(imag,real)>0)
            asm("bit clr FLAGS FLG0;");
        else
            asm("bit set FLAGS FLG0;");
        asm("bit tgl FLAGS FLG1;");
        if(offset>13)
            offset=0;
        else
            offset++;
This should give square wave in FLG0 because of linear phase shift (made by offset, it gives 2pi phase shift) in single point DFT calculation, but it produces many glitches
