Kernel Panic booting Linux on Zynq w/ ADV7511
Question asked by JCTsunami on Aug 5, 2013
Latest reply on Aug 19, 2013 by larsc
I'm looking for help to following set of instructions "LINUX WITH HDMI VIDEO OUTPUT ON THE ZED AND ZC702 BOARDS"
http://wiki.analog.com/resources/tools-software/linux-drivers/platforms/zynq
I follow the instruction almost verbatim and consistently get a kernel panic error. The only modification is I build 'zynq-zc702-adv7511.dts' instead of the device tree listed in the sample commands. As per other threads, I'm using the latest available versions on the adi git repository for the IP cores and the linux kernel.
Output from the boot sequence is copied below. It appears the kernel crashes right when trying to start the init sequence on the file system (Linaro).
I'd very much appreciate any tips as to how to debug this issue.
Johnnie
TCP: cubic registered
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
Registering SWP/SWPB emulation handler
axi-hdmi 70e00000.axi_hdmi: No connectors reported connected with modes
[drm] Cannot find any crtc or sizes - going 1024x768
usb 1-1: new low-speed USB device number 2 using xusbps-ehci
Console: switching to colour frame buffer device 128x48
axi-hdmi 70e00000.axi_hdmi: fb0:  frame buffer device
axi-hdmi 70e00000.axi_hdmi: registered panic notifier
[drm] Initialized axi_hdmi_drm 1.0.0 20120930 on minor 0
rtc-pcf8563 5-0051: low voltage detected, date/time is not reliable.
rtc-pcf8563 5-0051: setting system clock to 2058-12-26 03:39:02 UTC (2808099542)
ALSA device list:
  #0: HDMI monitor
EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
VFS: Mounted root (ext4 filesystem) on device 179:2.
Freeing unused kernel memory: 172K (c0546000 - c0571000)
request_module: runaway loop modprobe binfmt-0000
input: CHICONY USB NetVista Full Width Keyboard as /devices/amba.1/e0002000.usb/xusbps-eh
ci.0/usb1/1-1/1-1:1.0/input/input0
hid-generic 0003:04B3:3025.0001: input,hidraw0: USB HID v1.10 Keyboard [CHICONY USB NetVi
sta Full Width Keyboard] on usb-xusbps-ehci.0-1/input0
Kernel panic - not syncing: No init found.  Try passing init= option to kernel. See Linux
Documentation/init.txt for guidance.
CPU: 1 PID: 1 Comm: swapper/0 Not tainted 3.10.0-g68b7238 #10
[<c0012e7c>] (unwind_backtrace+0x0/0xe0) from [<c0010fc0>] (show_stack+0x10/0x14)
[<c0010fc0>] (show_stack+0x10/0x14) from [<c03a7110>] (panic+0x88/0x1e4)
[<c03a7110>] (panic+0x88/0x1e4) from [<c03a2cd8>] (kernel_init+0xb8/0xe4)
[<c03a2cd8>] (kernel_init+0xb8/0xe4) from [<c000ddc8>] (ret_from_fork+0x14/0x2c)
CPU0: stopping
CPU: 0 PID: 0 Comm: swapper/0 Not tainted 3.10.0-g68b7238 #10
[<c0010fc0>] (show_stack+0x10/0x14) from [<c0011f38>] (ipi_cpu_stop+0x3c/0x6c)
[<c0011f38>] (ipi_cpu_stop+0x3c/0x6c) from [<c00121d0>] (handle_IPI+0x5c/0x7c)
[<c00121d0>] (handle_IPI+0x5c/0x7c) from [<c0008504>] (gic_handle_irq+0x58/0x60)
[<c0008504>] (gic_handle_irq+0x58/0x60) from [<c000d8c4>] (__irq_svc+0x44/0x78)
Exception stack(0xc0573f70 to 0xc0573fb8)
3f60:                                     00000001 c057c6c8 00000000 c057c6c8
3f80: c0572000 c05aed00 c03b0d00 c0566848 c12d2f00 413fc090 00000000 00000000
3fa0: 00000000 c0573fb8 c005f530 c000e900 20000113 ffffffff
[<c000d8c4>] (__irq_svc+0x44/0x78) from [<c000e900>] (arch_cpu_idle+0x28/0x30)
[<c000e900>] (arch_cpu_idle+0x28/0x30) from [<c0052458>] (cpu_startup_entry+0xb4/0x118)
[<c0052458>] (cpu_startup_entry+0xb4/0x118) from [<c05467cc>] (start_kernel+0x2c0/0x314)
drm_kms_helper: panic occurred, switching back to text console
