ADV7181D CVBS 480i in, YUV422 20 bit out
Question asked by cdumont on Aug 2, 2013
Latest reply on Aug 5, 2013 by mattp
I'm using an ADV7181D in a system and feeding it NTSC at 480i.  I've configured the output to be 20 bits.  I'm getting 720 x 253 out instead of 720 x 240.  Here is my init script.  0x21 is the I2C address.  The register address and data follows.  Can you help pinpoint what's wrong?  Thank you.
##SD CVBS##
#:AUTODETECT CVBS IN NTSC/PAL/SECAM, 20-Bit 422 encoder:
./Test_Drv_I2c_Write8 /dev/i2c/0 0x21 1D 47 # Enable 28MHz Crystal
./Test_Drv_I2c_Write8 /dev/i2c/0 0x21 8F 50 # LLC2
./Test_Drv_I2c_Write8 /dev/i2c/0 0x21 00 0B # CVBS input on AIN1
./Test_Drv_I2c_Write8 /dev/i2c/0 0x21 03 05 # 20 Bit Mode
./Test_Drv_I2c_Write8 /dev/i2c/0 0x21 6B 80 # Use DE instead of FLD
./Test_Drv_I2c_Write8 /dev/i2c/0 0x21 04 00
./Test_Drv_I2c_Write8 /dev/i2c/0 0x21 C3 09
./Test_Drv_I2c_Write8 /dev/i2c/0 0x21 C4 C0
./Test_Drv_I2c_Write8 /dev/i2c/0 0x21 17 41 # select SH1
