data transfer through DMA's  external port
Question asked by gunnros on May 11, 2010
Latest reply on May 12, 2010 by jeyanthi.jegadeesan
I 'm working on Adsp - 21065L platform and  VisualDSP release 4.5.
My task is to interface an external device (MCU) through DMA's external port channel 8 , e.g. using EPB1 buffer, configured in handshake, for transfering a single 16 bit word every ms. The parameter registers are set as follows:
IEP1 = oxoooodooo
IMEP1 = 1;
CEP1 = 1;
Data transfers are completed succesfully, but...
Fistly, when configuring DMAC1 register in my code i observe that some instructions do not actually affect some bits. Particularly, this happens when i disable chaining by setting chen - 0 and CPEP1 - 0x0000 but DMAC1 register window shows it active (it was initially).
The thing is that i want the proccesor to "knows" when a single word tranfer is done so as to start proccesing....but,  DMASTAT steadilly shows this value:
which comes with disagreement with what DMAC1 shows (channel's active) and so polling does not work for determining the end of a transfer.
When i unmask DMA interrupts, no interrupt is generated when counter register decreaments to zero although i set PCI bit at CPEP1 register ( i do that to enable interrupts cause as i said chaining seems unaffected and active). So, i ask: am i missing something or shall i talk to the support?
Michael
_____________________________________________________________________________________________________________________________
Here's my code
                                                       // note: DMA_ISR is mapped at "isr_tbl.asm" interrupt vector table file
#include <def21065L.h>
#include <signal.h>
//#include "new65Ldefs.h"
#define SAMPLING_PERIOD 0x11E0B8AB     //0x0000EA54: 1ms
#define JUMP_INSTR_OPCODE 0x063E0000
#define RTI_INSTR_OPCODE 0x0B3E0000
#define TMZLI_VEC 0x0000805C
#define FLAG10O 6
#define FLAG10 6
.GLOBAL main_routine;
.GLOBAL TMZLI_isr;
.GLOBAL DMA_ISR;
.segment /dm dm_data;
.VAR index = 0;
.endseg;
.segment /pm pm_code;
main_routine:
    call place_timerISR;
    call set_timer;
    R0 = dm(IOCTL);
    R1 = 0x4B;
    R0 = R0 OR R1;;
    dm(IOCTL) = R0;
    R2 = dm(IOSTAT);
    R2 = bset R2 by 1;
    R3 = 0xBD;
    R2 = R2 AND R3;
    dm(IOSTAT) = R2;
    call set_DMA;
    NOP;
/*wait_trf_comlp:
   R14 = dm(DMASTAT);
   btst R14 by 7;
   if NOT SZ jump wait_trf_comlp;
   bit clr mode2 TIMEN0;
   R2 = dm(IOSTAT);
   R2 = bclr R2 by 3;
   dm(IOSTAT)= R2;*/
_sit:
    NOP;
    idle;
    jump _sit;
main_routine.end:
place_timerISR:
    PX2 = JUMP_INSTR_OPCODE;
    PX1 = TMZLI_isr;
    pm(TMZLI_VEC) = PX;
    PX2 = RTI_INSTR_OPCODE;
    PX1 = 0;
    pm(TMZLI_VEC + 1) = PX;
    pm(TMZLI_VEC + 2) = PX;
    pm(TMZLI_VEC + 3) = PX;
    //FLUSH CACHE;
            RTS;
set_timer:
   bit clr mode2 INT_HI0;
   bit set mode2 PWMOUT0 | INT_HI1;
   bit set mode1 IRPTEN;
   bit clr mode1 NESTM;
   bit set IMASK TMZLI;
   R1 = SAMPLING_PERIOD;
   dm(TPERIOD0) = R1;
   R2 = 1;
   dm(TPWIDTH0) = R2;
   bit set mode2 TIMEN0;
   RTS;
TMZLI_isr:
   R8 = dm(IOSTAT);
   //R7 = FLAG10;
   R8 = bset R8 by FLAG10;
   dm(IOSTAT) = R8;
   R3 = dm(index);
   R3 = R3 + 1;
   dm(index) = R3;
   R7 = 0x01;
   R4 = R3 AND R7;
   if EQ jump even;
odd:
   R6 = dm(IOSTAT);
   R6 = bset R6 by 0;
   dm(IOSTAT) = R6;
   jump intr_end;
even:
   R6 = dm(IOSTAT);
   R6 = bclr R6 by 0;
   dm(IOSTAT) = R6;
intr_end:
   R8 = dm(IOSTAT);
   R8 = bclr R8 by FLAG10;
   dm(IOSTAT) = R8;
   RTI;
TMZLI_isr.end:
set_DMA:
   R12 = dm(DMAC1);
   R12 = bclr R12 by 0;
   dm(DMAC1) = R12;
   R5 = dm(DMAC1);
   R7 = 0x0440;
   R5 = R5 OR R7;
   dm(DMAC1) = R5;
   R5 = dm(DMAC1);
   R7 = 0xC459;
   R5 = R5 AND R7;
   dm(DMAC1) = R5;
   R10 = 0x0000d000;
   dm(IIEP1) = R10;
   R5 = 1;
   dm(IMEP1) = R5;
   R6 = 1;//20;
   dm(CEP1) = R6;
   R0 = 0x00000;
   dm(GPEP1) = R0;
   R14 = dm(CPEP1);
   R13 = 0x0000;
   R14 = R14 AND R13;
   //R14 = bset R14 by 17;
   dm(CPEP1) = R14;
   R4 = 0x00080000;
   dm(EIEP1) = R4;
   dm(EMEP1) = R6;
   bit set IMASK EP1I;
   R4 = dm(DMAC1);
   R4 = bset R4 by 0;
   dm(DMAC1) = R4;
   RTS;
DMA_ISR:
   bit clr IMASK TMZLI;
   R12 = dm(DMAC1);
   dm(DMAC1) = R12;
   R2 = dm(IOSTAT);
   R2 = bclr R2 by 3;
   dm(IOSTAT)= R2;
   RTI;
DMA_ISR.end:
.endseg;
DMASTAT = 21AD6B5A
