I have a problem to configure the AD9915
Question asked by hanseyo on Jul 29, 2013
Latest reply on Dec 19, 2015 by kalupen
I am trying to effort to configure the AD9915 using parallel mode. I done configuration logic xilinx FPGA and use a 25MHz as configuration clock.
But I couldn't see the SYNC_CLK from pin-82 of AD9915 and couldn't read back register also.
I did as below.
1. power-up the board
2. confirmed the reference DDS input clock of 2.5GHz
3. send the master reset
4. confirmed the DDS external power down pin
5. confirmed if the SYNC_CLK appeared at pin-82 or not but I couldn't see the SYNC_CLK
Parameter setting is same as below.
Address      Name              Value
0x00           CFR1:LSB       0x0308
0x02           CFR1:MSB      0x0001
0x04           CFR2:LSB       0x0A00
0x06           CFR2:MSB      0x0040
0x08           CFR3:LSB       0x191C
0x0A           CFR3:MSB      0x0000
0x0C           CFR4:LSB       0x3120
0x0E           CFR4:MSB      0x0005
0x2C           Profile0FTW     0xB852
0x2E           Profile0FTW     0x051E
0x30           Profile0POW    0x0000
0x32           Profile0ASF      0x07FF
0x6C          USR0:LSB        0x0800
0x6E          USR0:MSB       0x0000
I attached the capture file of xilinx chipscope.
where, LSB of address bit is truncated.
Please let me know read-back and SYNC_CLK confirmation method.
Thank you.
