ADXL345 / 350 offset problems
Question asked by Turboman on Jul 25, 2013
Latest reply on Aug 1, 2013 by Turboman
Hi, I have a question regarding ADXL350 operating voltage. It specifies 2.0 - 3.6V, the same as the ADXL345.
However, I have seen from operating the ADXL345 @ 3.3V that there is significant offset on the X / Y axes.
The ADXL345 document says this:
[quote]
The ADXL345 is tested and specified at a supply voltage of
VS = 2.5 V; however, it can be powered with VS as high as 3.6 V
or as low as 2.0 V. Some performance parameters change as the
supply voltage changes: offset, sensitivity, noise, self-test, and
supply current.
[/quote]
So, can anyone tell me if I should use 2.5V ONLY to supply the ADXL350? Or, are voltages other than 2.5V going to cause offset on the ADXL350 as well?
