BF527 UART0 and UART1 at same time
Question asked by uriy on Jul 24, 2013
Latest reply on Jul 26, 2013 by Andreas
I have source code of UART driver which was used in BF533.
And it works fine in BF533.
BF527 has two uarts and I need both at same time.
BF527 sends a lot of data in both uarts.
Sometimes something happens and one of uart and later both uart doesn't work on transmitting.
Receiving works fine and other my code works fine.
I try to debug with ICE-100B it looks that THR empty interrupt doesn't occurs.
Below is init code, putchar and interrupt. I'll be glad to see source code, if anybody can give me
  * @brief  UART interface initialization
  *                     GPIO function set, interrupts enable
  * @param           uartnum uart number 0 or 1
  * @return baudrate uart baudrate bit per second
int InitUart(u32 uartnum, u32 baudrate)
          int ret = 1;
    register_handler(ik_ivg10, UART_ISR);                    // UART RX ISR             -> IVG 10
    register_handler(ik_ivg7, UART_ERR_ISR);          // UART Error ISR -> IVG 7
          baudrate = GetSCLK()/16/baudrate;
          if(uartnum == 0)
                    *pUART0_GCTL |= UCEN;               // enable clock
                    *pUART0_LCR |= DLAB;                  // enable acces to DLL and DLH
                    *pUART0_DLL = (char)baudrate;          // BAUD_RATE = (27MHz*10(MSEL))/(5*16*57600)
                    *pUART0_DLH = (char)(baudrate>>8);     //
                    *pUART0_LCR = 0x03;
                    *pPORTG_FER |= (PG7 | PG8);
                    *pPORTG_MUX |= (1<<5);
                    *pPORTG_MUX &= ~(1<<4);
               //*pUART0_IER |= ELSI;                     //enable UART ERR interrupt
               *pUART0_IER = ERBFI | ETBEI;                                        // enable rx tx uart interrupt
               *pSIC_IMASK0 |= IRQ_DMA8 | IRQ_DMA9;                    // enable UART RX, UART TX interrupt
          else if(uartnum == 1)
               *pUART1_GCTL |= UCEN;          // enable clock
               *pUART1_LCR |= DLAB;          // enable acces to DLL and DLH
               *pUART1_DLL = (char)baudrate;          // BAUD_RATE = (27MHz*10(MSEL))/(5*16*57600)
               *pUART1_DLH = (char)(baudrate>>8);     //
               *pUART1_LCR = 0x03;
               *pPORTF_FER |= 0xC000;
               *pPORTF_MUX |= 0x0800;
               //*pUART_IER |= ELSI;                     //enable UART ERR interrupt
               *pUART1_IER = ERBFI | ETBEI;                                        // enable rx tx uart interrupt
               *pSIC_IMASK0 |= IRQ_DMA10 | IRQ_DMA11;                    // enable UART RX, UART TX interrupt
               //xdev_out(putchar_UART1);
               //xdev_in(getchar_UART1);
               xdev_out(putchar_UART0);
               xdev_in(getchar_UART0);
               getchar_argon = getchar_UART1;
               putchar_argon = putchar_UART1;
          else
                    ret = -1;          // uart number doesn't exists
          return ret;
void putchar_UART0(char ch)
          unsigned int intr_mask;
  while (tx_counter_0 == TX0_BUFFER_SIZE);
    intr_mask = cli();                              //disable interrupt, save IMASK register into intr_mask
          if (tx_counter_0 || ((*pUART0_LSR & THRE)==0))                    // write into buffer if (tx_counter != 0) or UART is busy
                         tx_buffer_0[tx_wr_index_0] = ch;
                         tx_wr_index_0++;
                         if (tx_wr_index_0 == TX0_BUFFER_SIZE) tx_wr_index_0=0;
                         tx_counter_0++;
          else
                         *pUART0_THR = ch;
          sti(intr_mask);
void putchar_UART1(unsigned char ch)
    while (tx_counter_1 == TX1_BUFFER_SIZE);
          if (tx_counter_1 || ((*pUART1_LSR & THRE)==0))                    // write into buffer if (tx_counter != 0) or UART is busy
          tx_buffer_1[tx_wr_index_1] = ch;
          tx_wr_index_1++;
          if (tx_wr_index_1 == TX1_BUFFER_SIZE) tx_wr_index_1=0;
          tx_counter_1++;
          else
                    *pUART1_THR = ch;
          sti(intr_mask);                                        //enable interrupt
EX_INTERRUPT_HANDLER(UART_ISR)
          char z,data_0, data_1;
          unsigned short int_ident_0, int_ident_1;          //UART Interrupt identification register
///////////For Interrupt From UART0//////////////////////////////////
//          *pPORTGIO_TOGGLE = PG_GREEN_LED;
          int_ident_0 = *pUART0_IIR;
          int_ident_0 >>= 0x01;
          switch(int_ident_0)
                    case 0x00:
                        break;
                    } // end case 0x00
                    case 0x01:          // UART_THR is empty
                              if(tx_counter_0)
                                        tx_counter_0--;
                                        *pUART0_THR = tx_buffer_0[tx_rd_index_0];
                                        tx_rd_index_0++;
                                        if (tx_rd_index_0 == TX0_BUFFER_SIZE) tx_rd_index_0=0;
                              break;
                    } // end case 0x01
                    case 0x02:          // receive data ready
                              while (!(*pUART0_LSR & DR));
                              data_0 = *pUART0_RBR;
                              ssync();
                              rx_buffer_0[rx_wr_index_0] = data_0;
                              rx_wr_index_0++;
                              if(rx_wr_index_0 == RX0_BUFFER_SIZE)          rx_wr_index_0 = 0;
                              rx_counter_0++;
                              if(rx_counter_0 == RX0_BUFFER_SIZE)
                                        rx_counter_0 = 0;
                                        printf_UART0("\n\rx_buffer_1 overflow\n\r");
                        break;
                    } // end case 0x02
          } // end switch(int_ident)
///////////For Interrupt From UART1//////////////////////////////////
          int_ident_1 = *pUART1_IIR;
          int_ident_1 >>= 0x01;
          switch(int_ident_1)
                    case 0x00:
                        break;
                    } // end case 0x00
                              if(tx_counter_1)
                                        tx_counter_1--;
                                        *pUART1_THR = tx_buffer_1[tx_rd_index_1];
                                        tx_rd_index_1++;
                                        if (tx_rd_index_1 == TX1_BUFFER_SIZE) tx_rd_index_1=0;
                              break;
                    } // end case 0x01
                              while (!(*pUART1_LSR & DR));
                              data_1 = *pUART1_RBR;
                              ssync();
                              rx_buffer_1[rx_wr_index_1] = data_1;
                              rx_wr_index_1++;
                              if(rx_wr_index_1 == RX1_BUFFER_SIZE)          rx_wr_index_1 = 0;
                              rx_counter_1++;
                              if(rx_counter_1 == RX1_BUFFER_SIZE)
                                        rx_counter_1 = 0;
                                        debugi("rx_buffer_1 overflow");
                        break;
                    } // end case 0x02
