Synchronising timer1?
Question asked by ThorMJ on Jul 23, 2013
Latest reply on Aug 22, 2013 by Dirk
I'm using timer1 to interrupt me when a modbus RTU packet is complete (3.5 chars of silence)...
The problem is that it doesn't seem to synchronise with a T1CLRI write; with the code below and an oscope attached to P0.4 and P1.2, I clearly see the characters coming in (edges of P0.4 --yellow trace), but the P1.2 (blue trace) seems to have a "spurious pulses" in the middle of the receive operation (P1.2 goes high despite no silence -- the only thing that sets P1.2 high is the Timer1 ISR).  The P1.2 wave appears to be the right width if you get more than 1 pulse, but I was expecting the line marked //RESET to reset the timer every time I see something in the serial port....
void sportsetup    (int Baud)
    int div;
    IRQEN &= ~BIT(UART_INT);            // Lock out interrupts
    COMIEN0 = 0;                        // during (re)configuration...
    // Initialize the UART for 9600-8-N
    GP1CON |= BIT0 + BIT4;  // Select UART functionality for P1.0/P1.1 (sin/sout)
    COMCON0 = BIT7;            // Enable access to COMDIV registers
/* Hardcoded Examples:
    COMDIV0 = 0x21;        //9600 Baud
-or-
    COMDIV0 = 0x02;            // 115,200
    COMDIV1 = 0x00;            // No High Byte.
    COMDIV2 = BIT(15) |        //FracDiv
                1<<11 |
                796;
    //Main divider
    div = (CLOCKSPEED / 16 / 2) / Baud;
    COMDIV1 = div >> 8;
    COMDIV0 = div & 0xFF;
    //Fractional divider
    div = ((CLOCKSPEED / 16 / 2) / div * 2048) / Baud - 2048;
    COMDIV2 = BIT(15)                        //Enable Fracdiv
                        | 1 << 11            //M hardcoded to 1
                        | (div & 0xFFFF);    //Fractional divisor
    //ToDo BugzID:203 - This (10*7/2) should work, but doesn't (20*7/2 does though)... don't know if the PC ain't fast enough or what...
    char35 = CLOCKSPEED / Baud * 10 * 7 / 2;
    COMCON0 = BIT0 + BIT1;    //Drop DLAB, go to 8N1 mode
    COMCON1 = 0x03;            // Release the line
    //Init the fifo pointers
    txhead=txtail=rxhead=rxtail=0;
    //Start up the ISR:
    IntHndlrTable[UART_INT] = sportirq;    // Put the address in to the VIC table
    IRQEN |= BIT(UART_INT);                // Enable the VIC for the UART
    COMIEN0 = BIT0;                        // IRQ on RXd -- We'll enable the tx interrupt as part of the TX motion
    //Set up TIMER1 to handle the serial state transitions
    IntHndlrTable[T1_INT] = sporttimerirq;
    T1LD  = char35;            // Set the reload value based on baud rate
    T1CON = BIT9             // Core Clock
            | BIT6               //Periodic, not free-running so I can synchronize
            | BIT7            // Enabled
//This ISR is used to detect silence so we can deal with half duplex and can turn the line around properly
void sporttimerirq(void)
    if((comstatus == IDLE || comstatus == RXING)    //We're done
        && rxhead!=rxtail)                            //And we have chars rxfifo!
        comstatus = READY;                            //So, say we're "ready" instead of idle.
    /* The TX ISR routines also call for this to be fired at the end:
    *    1. The TX sets the comstatus so something else and I need to set it back if I had fifo
    *    2. TX gets called while there is still stuff going out; releasing the line then corrupts data.
    * So, we release it here.
    COMCON1 = 3;
    GP1DAT |= BIT2<<16;//DBG     --Debug- Make P1.2 go high indicating idle
    IRQCLR = BIT(T1_INT);                            //Turn ISR off until called for again.
void sportirq(void)
    char status;
    //Read the Interrupt ID register to clear it...
    status = COMIID0;
    // Read the the status register to figure out what to do:
    status = COMSTA0;
    GP0DAT ^= (BIT4<<16);//DBG --Mark chars as they come in or out
    T1CLRI = status;        //Reload the silence timer //RESET
    GP1DAT &= ~(BIT2<<16);//DBG     --Keep P1.2 low indicating activity
    if(status & 0x01)    //We have data incoming!
        comstatus = RXING;
        if(rxhead == rxtail-1 || (rxhead == 0 && rxtail == RXFIFO)) //We're full!
            comstatus = RXFIFOFULL;
            mbreg_ram.serstats.errors++;
        else
            rfifo[rxhead++] = COMRX;
            if (rxhead == RXFIFO)
                rxhead =0;
        RXHI();
    if(status & BIT1)
        mbreg_ram.serstats.overruns++;
    //Half duplex -- if someone is talking, don't talk over them.  This is not part of the above
    // -- I have to wait for the 3.5 char silence to expire before I start talking.
    if (comstatus == RXING)
        IRQEN = BIT(T1_INT);    //Turn on the silence timer if it was off before...
        return;                    //Skip the TX portion until the silence timer sez we're ok.
    // Gotta have this or we obliterate the 1st byte.  No idea why (I don't think I should've ISR'd).
    if((COMSTA0 & 0x20) == 0x00)
        return;
    //Transmit if we're ready.
    if (txhead != txtail) {
        COMCON1 = 0;            //Turn on RTS to take control of the RS485
        IRQCLR = BIT(T1_INT);    //Turn off the silence timer until end of packet.
        comstatus=TXING;
        COMTX = wfifo[txtail++];
        if(TXFIFO == txtail)
            txtail = 0;
    } else {                    //We're Done.  I have no more to put into empty TX register
        comstatus=IDLE;
        IRQEN = BIT(T1_INT);    // And turn it on (we're going to keep control of RS485 for 3.5 chars).
        COMIEN0 &= ~BIT1;        //Turn off THRE isr -- otherwise we keep triggering the IRQ cuz I dinna fill it.
                                //DON'T turn of using IRQEN -- we still need our RX irqs!
