ADA4899 disable pin
Question asked by onejk on Jul 23, 2013
Latest reply on Jul 30, 2013 by onejk
according to data sheet the ADA4899 works in normal mode if disable pin is left open.
Below 2,4V it is disabled, above 4,3V it is enabled with 'Low Input Bias Current' .
Is a voltage 2,4V ... 4,3V also allowed to enable normal mode?
The ADA4899 disable pin should be directly connected to a TTL output, where 3,3V should be equal to enabled
Jochen
