Need help regarding BF533 UART.
Question asked by mr_blackfin on Jul 23, 2013
Latest reply on Jul 24, 2013 by Andreas
Hardware : BF533 EZ KIT
I am trying to transmit data on UART using DMA Interrupt based method and trying to receive using Non DMA Interrupt based method.
However, when I am not able to receive characters on the UART.
Is there any special care to be taken while running UART in mixed mode?
Following is my code:
/*********INCLUDES************************************************************************/
#include<cdefBF533.h>
#include<stdio.h>
#include<sys/exception.h>
/*********GLOBALS************************************************************************/
char tx_buff[15] = {'H','e','l','l','o',' ','W','o','r','l','d','!','!','!'};
short temp;
char c;
char received_data_from_UART[10];
int count = 0;
char rx_buff[10];
struct command_structure_UART
    unsigned char start_byte;
    unsigned char transmitter_ID;
    unsigned char receiver_ID;
    unsigned char command_response_code;
    short length_of_data;
    unsigned char check_sum;
/*********FUNCTION DECLARATIONS************************************************************************/
void DMA_config_UART_TX(void);
EX_INTERRUPT_HANDLER(uart_transmit);
EX_INTERRUPT_HANDLER(uart_receive);
Function:     UART TX Interrupt Service Rouine.
Description: DMA based UART transmission
    if(*pDMA7_IRQ_STATUS & 0x0008)
    else
        *pDMA7_CONFIG = 0x0000;
    *pDMA7_IRQ_STATUS |= 0x0001;
    //printf("\n Interrupt \n");
    temp = *pUART_IIR;
    asm("nop;");
Function:      UART RX Interrupt Service Rouine.
Description: Read a character from RBR, and echo it to the UART.
             Reading RBR clears the interrupt request.
    if(*pDMA6_IRQ_STATUS & 0x0001)
        *pDMA6_CONFIG = 0x0000;
        c = *pUART_RBR;
        ssync();
        received_data_from_UART[count] = c;
        count++;
        printf("%c", c);
        *pDMA6_IRQ_STATUS |= DMA_DONE;
Function    :    DMA_configMain
                 Configure the DMA for UART transmission
    *pDMA7_CONFIG = 0x0;
    *pDMA7_START_ADDR = tx_buff;
    *pDMA7_X_COUNT = 0x000F;        //Specify number of bytes to be transmitted
    *pDMA7_X_MODIFY = 0x0001;
    *pDMA7_CONFIG = 0x0081;
    asm("ssync;");
Function    :    Main
                 UART Transmission done using DMA Interrupt based method.
                 Whereas, UART Reception done using non DMA Interrupt based method.
void main()
    register_handler(ik_ivg10, uart_transmit);
    register_handler(ik_ivg10, uart_receive);
    *pSIC_IMASK = 0x8000 | 0x4000;
    asm("ssync;");
    DMA_config_UART_TX();
    //configure UART
    *pPLL_DIV = 0x06;
    *pUART_LCR = 0x0080;
    *pUART_DLH = 0x02;
    *pUART_DLL = 0x84;
    *pUART_LCR = 0x0000;
    *pUART_LCR = 0x0003;
    *pUART_IER = 0x0002 | 0x0001;        //Enabling Tx and Rx interrupt
    *pUART_GCTL = 0x0001;
    Init_PLL();
    asm("ssync;");
    asm("nop;");
    while(1)
