Simple program to test ADSP-21488
Question asked by Kilohercas on Jul 22, 2013
Latest reply on Aug 2, 2013 by Kilohercas
Hello, could any one show example how to test my setup ?
( i made flash programmer, and development board,25MHz CLK, Boot config SPI_MASTER (01), and CLK konfig is 00)
In loader setup, should i sue SPI_FLASH, or SPI_MASTER ?
my program looks like this:
#include <def21488.h>
#include <cdef21488.h>
#include <math.h>
#include <SRU.h>
#include <asm_sprt.h>
asm("#include <def21489.h>");
#define NOP asm volatile("nop;")
void initPLL(void);
void Mandelbrot(float zoom);
int main( void )
    initPLL();
    asm("bit clr FLAGS FLG1;"); //CS LOW
    asm("bit set FLAGS FLG1;");//CS HIGH”
     while(1)
void initPLL(){
int i, pmctlsetting;
    // Set INDIV bit in PMCTL register
    pmctlsetting = *pPMCTL;
    pmctlsetting |= INDIV;
    *pPMCTL= pmctlsetting;
    // Program PLL multiplier to same value as CLK_CFGx pins/previously programmed value in software……
    *pPMCTL = pmctlsetting;
    // then place PLL in bypass mode
    pmctlsetting |= PLLBP;
    //Wait for recommended number of cycles
    for (i=0; i<4096; i++)
          NOP;
    // Bring PLL out of bypass mode by clearing PLLBP bit
    *pPMCTL ^= PLLBP;
    for (i=0; i<16; i++)
          NOP;
    // Clear the previous PLL multiplier
    pmctlsetting &= ~PLLM63;
    // Clear the INDIV bit
    pmctlsetting &= ~INDIV;
    // or set the INDIV bit
    // *pMCTL |= INDIV;
    // CLKIN= 25 MHz, Multiplier= 16, Divisor= 2, CCLK_SDCLK_RATIO 2.5.
    // Fcclk = (CLKIN * 2 * M) / (N * D)
    // VCO frequency = 2*fINPUT*PLLM = 2*25*16 = 800 <= fVCOmax (800 MHz)
    // M = 1 to 64, N = 2,4,8,16 and D = 1 if INDIV = 0, D = 2 if INDIV = 1
    pmctlsetting=SDCKR2_5|PLLM16|DIVEN|PLLD2;
    pmctlsetting|= PLLBP;    //Setting the Bypass bit
    pmctlsetting^= DIVEN;    //Clearing the DIVEN bit
    *pPMCTL= pmctlsetting;    // Putting the PLL into bypass mode
    //Wait for around 4096 cycles for the pll to lock.
    for (i=0; i<5000; i++)
          NOP;
    pmctlsetting ^= PLLBP;          //Clear Bypass Mode
          NOP;
Problem, i don't get any FLAG1 toggle, and i really don't know why,  (Photo of home made board for ADSP-21488, later it will be used in my master degree work, in university)
