Trouble with the Multiband Graphic Equalizer SDK, Linker Error
Question asked by chris_k. on Jul 22, 2013
Latest reply on Jul 23, 2013 by chris_k.
Hello Comunity,
i'm trying to use the Multiband Graphic Equalizer SDK from the Analog Devices website for a university project.
The SDK comes with  an example project (fileio) and i want to use it in my dual core project on the ADSZ-BF561-EZLITE board, on core A whitch does the signal processing.
Like described in the SDKs documentary i'm trying to use the SDK like in the example, but i get a linker error when i  try to  generate an equalizer instance.
What i do in my main file (core a):
outside the main routine i do this:
#include "adi_eq_audpp.h"
// Memory for graphic equalizer instance
char instance_memory[1764]; // eq-spec s. 3
// Memory for input and output buffers
int input_buffer[440];
int output_buffer[440];
in my main routinge (outside while(1)) i do this:
//equalizer
adi_eq_audpp_mem_t memory_blocks;
adi_eq_audpp_instance_t* instance = 0;
adi_eq_audpp_config_t configuration = {};
adi_eq_audpp_audio_data_t *input_pcm_data[1] = {input_buffer};
adi_eq_audpp_audio_data_t *output_pcm_data[1] = {output_buffer};
// use same equalizer configuration for all channels
configuration.num_channels = 2;
configuration.sample_rate = 44100;
configuration.num_bands = 3;
int gains = 1; //evtl. 1200
configuration.gains = &gains;
//single graphic equalizer instance
memory_blocks.state.fast.prio0 = instance_memory;
//here i get the error!!
instance = adi_eq_audpp_create(&memory_blocks);
In the last line i get the linker error listed below:
[Error li1021]  The following symbols referenced in processor 'p0' could not be resolved:
        'adi_eq_audpp_create_2_0 [_adi_eq_audpp_create_2_0]' referenced from 'corea.dlb[main_core_A.doj]'
I already tryed to include the "libadi_eq_audpp_bf.dlb" library file delivered with the SDK into my project. I'm not sure if i did this in the right way, i just added the file to the project and it was listed automatically in the linker files of core A. With this i get the linker error listed below:
[Warning li2060]  The following input section(s) that contain program code
        and/or data have not been placed into the executable for processor 'p0'
        as there are no relevant commands specified in the LDF:
        .\libadi_eq_audpp_bf.dlb[adi_eq_audpp.doj](adi_fast_prio0_code)
        .\libadi_eq_audpp_bf.dlb[adi_eq_audpp.doj](adi_slow_noprio_r)
[Error li1060]  The following symbols are referenced, but not mapped:
        '_adi_eq_audpp_create_2_0' referenced from corea.dlb[main_core_A.doj](program)
I'm a little overextended with this at the moment. Does someone of You see what i'm making wrong? Have i added the library to the project right like this?
Thank's in advance,
Chris
