Why do I lost one byte from SPI?
Question asked by dinrail on Jul 17, 2013
Latest reply on Jul 19, 2013 by dinrail
The SPI example folder is empty so I gave it a try with the following codes. I thought I created 3 bytes in Tx FIFO, so when I flush the FIFO, write two bytes in a roll via SpiTx, then wait, I should see the two bytes sent out on SPI bus, but I saw only one, the second one is lost. Why?
void SPI0INIT (void)
    pADI_GP1->GPCON = (pADI_GP1->GPCON&0x00ff)|0xaa00;
    SpiBaud(pADI_SPI0
    ,0  //baud rate is SPI UCLK/2x(iCLKDiv+1).
    ,SPIDIV_BCRST_DIS  //disable CS error detection
    SpiCfg(pADI_SPI0,
    SPICON_MOD_TX3RX3, //Rx and Tx FIFO sizes.
    SPICON_MASEN_EN, //enable SPI in Master mode.
    SPICON_CON_ED //enable continuous transfer
    |SPICON_TIM_TXWR //Initiate transfer with a write to the SPI TX register
    |SPICON_CPOL_HIGH //Serial clock idles high
    |SPICON_CPHA_SAMPLETRAILING //Serial clock pulses at the  start of the first data bit transfer
    |SPICON_ENABLE_EN //enable of the SPI peripheral
main ()
    ClkSel(CLK_CD7,CLK_CD7,CLK_CD0,CLK_CD7);     // Select CD0 for UART System clock
    SPI0INIT();
    while (1){
        SpiFifoFlush(pADI_SPI0, SPICON_TFLUSH_EN, SPICON_RFLUSH_EN);
        SpiTx(pADI_SPI0, 0x55);
        SpiTx(pADI_SPI0, 0xAA);
        for (jj=0; jj<10000; jj++){
*I tried both SPICON_CON_EN and SPICON_CON_DIS, SPICON_MOD_TX3RX3 and SPICON_MOD_TX2RX2,  and the result is the same
