AD1940,ADAU1446 - Output noise
Question asked by fernandes on Jul 17, 2013
Latest reply on Jul 29, 2013 by BrettG
Sirs
Testing the AD1940 and ADAU1446 Evaluations Boards, with a simple circuit (in directly to out), just using one channel (mono), I put a 1Khz sinus at input, and check the output test pin (with no loads). Let's see the signal. I've noted a noise over output signal at 45 Khz (AD1940) and 22 Khz (ADAU1446). Both running at 48 Khz (sampling rate). So I need a help if is normal, and how to avoid this.
Regards
Jean Fernandes
