dual-core communication between linux and cces on bf609-EZboard
Question asked by alen on Jul 17, 2013
Latest reply on Jul 25, 2013 by Aaronwu
Hi, All ADI experts
     I am learning dual-core communication between cces and linux,but when I use "icc_loader -l bf609_MCAPI_Core1.dxe" to load it to CoreB, Prompt an error!
     I paste my boot log:
U-Boot 2011.09 (ADI-2012R1) (May 23 2012 - 10:03:46)
CPU:   ADSP bf609-0.0 (Detected Rev: 0.0) (parallel flash boot)
Board: ADI BF609 EZ-Kit board
       Support: http://blackfin.uclinux.org/
Clock: VCO: 25 MHz, Core: 500 MHz, System0: 100 MHz, System1: 100 MHz, Dclk: 250 MHz
RAM:   128 MiB
Flash: ## Unknown flash on Bank 1 - Size = 0x00000000 = 0 MB
0 Bytes
MMC:   Blackfin SDH: 0
In:    serial
Out:   serial
Err:   serial
KGDB:  [on serial] ready
other init
Net:   mii1
Hit any key to stop autoboot:  0
bfin>
bfin> set serverip 192.168.2.101;set ipaddr 192.168.2.102;set gatewayip 192.168.2.1;tftp 0x1000000 uImage;bootm 0x1000000
Using mii1 device
TFTP from server 192.168.2.101; our IP address is 192.168.2.102
Filename 'uImage'.
Load address: 0x1000000
Loading: #################################################################
done
Bytes transferred = 16802537 (10062e9 hex)
## Booting kernel from Legacy Image at 01000000 ...
   Image Name:   bf609-0.0-3.5.7-ADI-2012R2
   Image Type:   Blackfin Linux Kernel Image (gzip compressed)
   Data Size:    16802473 Bytes = 16 MiB
   Load Address: 00001000
   Entry Point:  00257aec
   Verifying Checksum ... OK
   Uncompressing Kernel Image ... OK
Starting Kernel at = 00257aec
console [ttyBF0] enabled, bootconsole disabled
Calibrating delay loop... 995.32 BogoMIPS (lpj=1990656)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
devtmpfs: initialized
Blackfin Scratchpad data SRAM: 4 KB
Blackfin L1 Data A SRAM: 16 KB (9 KB free)
Blackfin L1 Data B SRAM: 16 KB (16 KB free)
Blackfin L1 Instruction SRAM: 64 KB (50 KB free)
Blackfin L2 SRAM: 256 KB (256 KB free)
NET: Registered protocol family 16
Blackfin DMA Controller
ezkit_init(): registering device resources
ezkit_init(): request emac pins failed
bio: create slab <bio-0> at 0
SCSI subsystem initialized
bfin-spi bfin-spi.0: master is unqueued, this is deprecated
bfin-spi bfin-spi.0: bfin-spi probe success
bfin-spi bfin-spi.1: master is unqueued, this is deprecated
bfin-spi bfin-spi.1: bfin-spi probe success
i2c-bfin-twi i2c-bfin-twi.0: Blackfin on-chip I2C TWI Contoller, regs_base@ffc01e00
i2c-bfin-twi i2c-bfin-twi.1: Blackfin on-chip I2C TWI Contoller, regs_base@ffc01f00
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
PTP clock support registered
NET: Registered protocol family 23
Switching to clocksource bfin_cs_cycles
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP: reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
msgmni has been set to 211
io scheduler noop registered (default)
bfin-uart: Blackfin serial driver
bfin-uart.0: ttyBF0 at MMIO 0xffc02000 (irq = 88) is a BFIN-UART
bfin-dma: initialized
Blackfin hardware CRC driver
bfin-crc bfin-crc.0: initialized
bfin-crc bfin-crc.1: initialized
physmap platform flash device: 01000000 at b0000000
physmap-flash.0: Found 1 x16 devices at 0x0 in 16-bit bank. Manufacturer ID 0x0000bf Chip ID 0x00235b
Support for command set 0701 not present
gen_probe: No supported Vendor Command Set found
physmap-flash physmap-flash.0: map_probe failed
m25p80 spi0.1: unrecognized JEDEC id 1f2600
CAN device driver interface
bfin_can bfin_can.0: bfin_can device registered(&reg_base=ffc00a00, rx_irq=47, tx_irq=48, err_irq=49, sclk=125000000)
        DWMAC100
No HW DMA feature register supported
Enhanced/Alternate descriptors
RX IPC Checksum Offload not configured.
stmmac_dvr_probe: warning: cannot get CSR clock
stmmac: probed
eth0: PHY ID 0000ffff at 1 IRQ 0 (stmmac-0:01) active
eth0: PHY ID 0000ffff at 2 IRQ 0 (stmmac-0:02)
eth0: PHY ID 0000ffff at 3 IRQ 0 (stmmac-0:03)
eth0: PHY ID 0000ffff at 4 IRQ 0 (stmmac-0:04)
eth0: PHY ID 0000ffff at 5 IRQ 0 (stmmac-0:05)
eth0: PHY ID 0000ffff at 6 IRQ 0 (stmmac-0:06)
eth0: PHY ID 0000ffff at 7 IRQ 0 (stmmac-0:07)
eth0: PHY ID 0000ffff at 8 IRQ 0 (stmmac-0:08)
eth0: PHY ID 0000ffff at 9 IRQ 0 (stmmac-0:09)
eth0: PHY ID 0000ffff at 10 IRQ 0 (stmmac-0:0a)
eth0: PHY ID 0000ffff at 11 IRQ 0 (stmmac-0:0b)
eth0: PHY ID 0000ffff at 12 IRQ 0 (stmmac-0:0c)
eth0: PHY ID 0000ffff at 13 IRQ 0 (stmmac-0:0d)
eth0: PHY ID 0000ffff at 14 IRQ 0 (stmmac-0:0e)
eth0: PHY ID 0000ffff at 15 IRQ 0 (stmmac-0:0f)
eth0: PHY ID 0000ffff at 16 IRQ 0 (stmmac-0:10)
eth0: PHY ID 0000ffff at 17 IRQ 0 (stmmac-0:11)
eth0: PHY ID 0000ffff at 18 IRQ 0 (stmmac-0:12)
eth0: PHY ID 0000ffff at 19 IRQ 0 (stmmac-0:13)
eth0: PHY ID 0000ffff at 20 IRQ 0 (stmmac-0:14)
eth0: PHY ID 0000ffff at 21 IRQ 0 (stmmac-0:15)
eth0: PHY ID 0000ffff at 22 IRQ 0 (stmmac-0:16)
eth0: PHY ID 0000ffff at 23 IRQ 0 (stmmac-0:17)
eth0: PHY ID 0000ffff at 24 IRQ 0 (stmmac-0:18)
eth0: PHY ID 0000ffff at 25 IRQ 0 (stmmac-0:19)
eth0: PHY ID 0000ffff at 26 IRQ 0 (stmmac-0:1a)
eth0: PHY ID 0000ffff at 27 IRQ 0 (stmmac-0:1b)
eth0: PHY ID 0000ffff at 28 IRQ 0 (stmmac-0:1c)
eth0: PHY ID 0000ffff at 29 IRQ 0 (stmmac-0:1d)
eth0: PHY ID 0000ffff at 30 IRQ 0 (stmmac-0:1e)
eth0: PHY ID 0000ffff at 31 IRQ 0 (stmmac-0:1f)
input: bfin-rotary as /devices/platform/bfin-rotary/input/input0
i2c /dev entries driver
bfin_wdt: initialized: timeout=20 sec (nowayout=0)
icc icc.0: initialized
TCP: cubic registered
can: controller area network core (rev 20090105 abi 8)
NET: Registered protocol family 29
dma_alloc_init: dma_page @ 0x02390000 - 1024 pages at 0x07c00000
Freeing unused kernel memory: 15320k freed
eth0: device MAC address 92:89:ef:3a:a8:59
stmmac_open: DMA initialization failed
BusyBox v1.20.2 (2013-06-09 09:32:39 CST) hush - the humble shell
root:/> cd bin/
root:/bin> icc_loader -l BF609_MCAPI_msg_Core1.dxe
writing to 0xff600000, 0xffb4    bytes: OK
writing to 0xff400458, 0x4       bytes: OK
writing to 0xff4034e0, 0x7cc     bytes: OK
writing to 0xff400000, 0x458     bytes: OK
writing to 0xff400460, 0x3080    bytes: OK
writing to 0xff40045c, 0x4       bytes: OK
writing to 0xff403cac, 0x308     bytes: OK
writing to 0xff50008c, 0xc       bytes: OK
writing to 0xff502e18, 0x7a4     bytes: OK
writing to 0xff500000, 0x8c      bytes: OK
writing to 0xff5000a0, 0x2d78    bytes: OK
writing to 0xff5035bc, 0x59b     bytes: OK
writing to 0xff500098, 0x4       bytes: OK
writing to 0xff503b58, 0x74      bytes: OK
writing to 0xff50009c, 0x0       bytes: OK
writing to 0xff50009c, 0x4       bytes: OK
writing to 0xff503bcc, 0x3e8     bytes: OK
writing to 0xff503fb4, 0x0       bytes: OK
writing to 0xc80a802c, 0x2c28    bytes: OK
writing to 0xc8088210, 0x9e4     bytes: OK
writing to 0xc80a8000, 0x1a      bytes: OK
writing to 0xc80aac54, 0x15360   bytes: OK
writing to 0xc8088bf4, 0x400     bytes: OK
writing to 0xc80a801c, 0x10      bytes: OK
ERROR: Your destination address looks wrong: 0x4000000
The max mem available on your system seems to be 0x07888000,
but the destination is above that; aborting.
(re-run with --force to skip this check)
writing to 0x04000000, 0x1e308   bytes: FAILED
ERROR: Your destination address looks wrong: 0x401e308
writing to 0x0401e308, 0x2c7624  bytes: FAILED
ERROR: Your destination address looks wrong: 0x42e5940
writing to 0x042e5940, 0x682588  bytes: FAILED
ERROR: Your destination address looks wrong: 0x5000000
writing to 0x05000000, 0x14      bytes: FAILED
ERROR: Your destination address looks wrong: 0x5000014
writing to 0x05000014, 0x394ae4  bytes: FAILED
ERROR: Your destination address looks wrong: 0x6000000
writing to 0x06000000, 0x18fac   bytes: FAILED
ERROR: Your destination address looks wrong: 0x6018fac
writing to 0x06018fac, 0xe4      bytes: FAILED
ERROR: Your destination address looks wrong: 0x7000000
writing to 0x07000000, 0x561a    bytes: FAILED
root:/bin>
