I can't erase ADuCM360, any pointer?
Question asked by dinrail on Jul 16, 2013
Latest reply on Jul 16, 2013 by dinrail
I just got a new PCB to try out ADuCM360 again, and ran into some problem, I can't erase it, so I would appreciate it if you can give me a pointer
I had three previous revs of PCBs and I never had issue with programming/erasing ADuCM360.
This time, I don't think I change anything around the micro to affect this area, but I can't erase it any more. I compared the signal on this board with the other working ones and I didn't see any difference in the scope: RESET is high, 3.3V is solid, SWDIO and SWCLK has signal during erasing, and the JLINK's erase command returns:
* JLink Info: Device "ADUCM360" selected (0 KB flash, 0 KB RAM).
Set JLink Project File to "C:\Keil\Analog\examples\Adc\JLinkSettings.ini"
JLink info:
DLL: V4.51g, compiled Jul 11 2012 20:31:55
Firmware: J-Link ARM Lite V8 compiled Jun 19 2012 14:36:11
Hardware: V8.00
S/N : 228200192
* JLink Info: Found SWD-DP with ID 0x2BA01477
* JLink Info: FPUnit: 6 code (BP) slots and 2 literal slots
* JLink Info: Found Cortex-M3 r2p0, Little endian.
ROMTableAddr = 0xE00FF003
Target info:
Device: ADuCM360
VTarget = 3.358V
State of Pins:
TCK: 0, TDI: 1, TDO: 1, TMS: 1, TRES: 1, TRST: 1
Hardware-Breakpoints: 6
Software-Breakpoints: 8192
Watchpoints:          4
JTAG speed: 2000 kHz
***JLink Error: Can not read register 15 (R15) while CPU is running
**JLink Warning: CPU could not be halted
***JLink Error: Could not read memory location 0x20000000 when trying to clear soft RAM BP
Could not start CPU core. (ErrorCode: -1)
***JLink Error: Can not read register 20 (CFBP) while CPU is running
***JLink Error: CPU is not halted
Full Chip Erase Failed!
I've tried two micros already, with the same result.
What could be wrong? Thanks for any pointer!
