[bug report]  DmaErrorIntHandler() of adi_dma_bf60x.c
Question asked by chris@dw on Jul 5, 2013
Latest reply on Jul 15, 2013 by bala
I just found a bug in the DmaErrorIntHandler() of adi_dma_bf60x.c
take the run time value of :
AdiDmaBitWiseRegistry[0] = 0x20000000
AdiDmaBitWiseRegistry[1] = 0x00000002
the registered ChannelNumber should be 29 and 33
but, the following code turns out to be 29 and 31
"C:\Analog Devices\CrossCore Embedded Studio 1.0.2\Blackfin\lib\src\services\source\dma\adi_dma_bf60x.c"
static void DmaErrorIntHandler(uint32_t SID, void *pCBParam)
..... code skipped
    /* DMA Channel number to which the interrupt belongs */
    uint8_t     ChannelNumber = 0;
    /* Bitwise registry value to work on */
    uint32_t    OpenChannels;
    /* FOR (All Bitwise registy entries) */
    for (i = 0; i < ADI_DMA_NUM_REGISTRY; i++) <== ChannelNumber should reset as i*32
        /* FOR (All DMA channels marked as open in this bitwise registry) */
        for (OpenChannels = AdiDmaBitWiseRegistry[i]; OpenChannels > 0; )
            /* IF (This DMA Channel is open) */
            if ((OpenChannels & 1) == 1u)
                /* IF (DMA error is for this channel) */
..... code skipped
                    /* Found DMA channel that generated the error interrupt */
                    bChannelFound = true;
                    /* quit this loop */
                    break;
                } /* End of IF (DMA error is for this channel) */
            } /* End of IF (This DMA Channel is open) */
            /* Move to next DMA channel */
            OpenChannels >>= 1;
            /* Increment channel number */
            ChannelNumber++;
        } /* End of FOR (All DMA channels marked as open in this bitwise registry) */
        /* IF (Found DMA channel that generated the error interrupt) */
        if (bChannelFound)
            break;
    } /* End of FOR (DMA channels that are open) */
