AD9958 programming
Question asked by greenhorn on Jul 2, 2013
Latest reply on Jul 12, 2013 by sitti
I am currently trying to program the AD9958 Chip via a AT91SAM3U4E mikrocontroller from Atmel, but it is not working.
The Chip select signal is set low and the SCLK is running but when i download my code there's no output on the AD9958.
This is my code:
//Configure SPI
  SPI_Config();
  //Configure Outputs
  OUT_Config();
  //master Reset, Set Pin18 HIGH
  OUT_Set(18);
  //delay in milliseconds
  delay(1);
  //Set Pin 18 LOW
  OUT_Clear(18);
  delay(1);
  // Transmit data, Function Registers
  SPI_Write(0x01);                   // Instruction byte, write FR1 in MSB mode
  SPI_Write(0x800);                 // FR1 DATA
  SPI_Write(0x000);                 // FR1 DATA
  SPI_Write(0x03);                  // Instruction byte, write CFR in MSB mode
  SPI_Write(0x000);                 // CFR DATA
  SPI_Write(0x301);                 // CFR DATA
  //IO-Update
   OUT_Set(20);
   delay(1);
  OUT_Clear(20);
  delay(1);
  //Transmit data, FTW for each channel
  // Channel 0
  SPI_Write(0x00);              // Instruction byte, write CSR in MSB mode
  SPI_Write(0x42);              // CH0, SPI 3-Wire Mode, MSB first
  SPI_Write(0x04);              // Instruction byte, write CFTW0 in MSB mode
  SPI_Write(0x1BA5);            // FTW0 for fout=54 MHz, fclock=500 MHz, N=32
  SPI_Write(0xE354);            // FTW0 for fout=54 MHz, fclock=500 MHz, N=32
  //IO-Update
   OUT_Set(20);
  //delay
   delay(1);
  OUT_Clear(20);
  delay(1);
  // Channel 1
  SPI_Write(0x82);              // CH1, SPI 3-Wire Mode, MSB first
  SPI_Write(0x1BA5);            // FTW1 for fout=53.999 MHz, fclock=500 MHz, N=32
  SPI_Write(0xC1C6);            // FTW1 for fout=53.999 MHz, fclock=500 MHz, N=32
  //IO-Update
   OUT_Set(20);
  //delay
   delay(1);
  OUT_Clear(20);
  delay(1);
  return 0;
I would be very thankful for any suggestions... i just don't get it working. The attached file is the schematic of the DDS Chip.
greenhorn
