ADV7403 I2C read issue
Question asked by HankZ on Jun 24, 2013
Latest reply on Jul 12, 2013 by DaveD
I have developed an interface board to receive VGA data and output to RGB888
(24 bit RGB digital data).  I am having an issue where the I2C appears to be
programming the device correctly but read-back does not appear to work.  I have
worked on this for the last few days and thought that several things could be
wrong.  First, I connected TEST0 and TEST1 per the evaluation board design of
the 7403.  I have since disconnected these lines and there is no change.  I
have modified my I2C pullups and series resistors and this has not had an
impact.  When I write data, the device acknowledges on the 9th bit correctly.
When I read data, I get the slave acknowledge up and until I begin to generate
clocks and perform a master acknowledge to the device.  The device appears to
not be giving any data back.  I also know that through the configurations I
have programmed, the pixel clock should be specific frequencies (65MHz, 75MHz,
etc.).  I have confirmed that these frequencies are in place so I am certain
that the device is operational.  I am just uncertain as to why it appears to be
block from the reads.  I am using a PIC 32MX795F512L with integrated I2C
peripheral to talk.  Any help would be greatly appreciated.
