Matlab and Simulink with Analog Discovery
Question asked by Deiv on Jun 23, 2013
Support for the Analog Discovery to be used as a Data Acquisition device with the Mathwork's Matlab is provided via a support package downloadable at the link below.
http://www.mathworks.in/hardware-support/digilent-analog-discovery.html
Here below is an example of how to use the Matlab with the Sessions-Based Interface.
http://www.mathworks.in/help/daq/examples/using-the-session-based-interface-with-digilent-analog-discovery-hardware.html
But support for continuous sampling is not available !
My target was to continually sample a channel at low (8kHz) sample rate continually, make a real time digital signal processing with Simulink and send it to the AWG outputs.
1. Can someone help on how a low frequency continual sampling is possible?
2. Also how to use it in conjunction with the Simulink?
I tried out some code as below... This code continually updates the data samples every 100ms. It has flexible voltage ranging and also sampling.
% Repetitive data acquisition from Analog Discovery - Analog input Channel 1
time = 0.1;
rate = 32e3/time;
if rate > 1e6
    rate = 1e6;
    time = 32e3/rate;
end
xmin = 0;
xmax = time;
% Acquiring Code
ch1 = daq.createSession('digilent');
ch1.addAnalogInputChannel('AD1', 1, 'Voltage');
ch1.Rate = rate;
ch1.Channels.Range = [-25 25];
ch1.DurationInSeconds = xmax;
%[data, timestamps, triggerTime] = ch1.startForeground;
while true
    pause(0.1);
    ymax = max(data);
    ymin = min(data);
    if(max(abs(ymax), abs(ymin)) <= 2.5)
        ch1.Channels.Range = [-2.5 2.5];
    else
    end
    plot(timestamps, data, 'g');
    axis([xmin xmax ymin ymax]);
end
If this question is not to be addressed here, please advise if Mathworks or Digilent can help. Thanks.
- Deiv
