ADV7842 decolder in bf609 EZ Board
Question asked by alen on Jun 21, 2013
Latest reply on Jun 21, 2013 by GuenterL
Hi !  ADI's experts
I am interested in Analog Devices video decoder/encoder chip, p/n ADV7842,and I have configed linux kernel and buildroot used make linux-menuconfig and make menuconfig,my configuration is as follows:
first :execute make menuconfig
          Blackfin Processor Options  --->
                   Uncached DMA region (Enable 4M DMA region)  --->
second:make linux-menuconfig
          Device Drivers  --->
                 <M> I2C support  --->
                                     I2C Hardware Bus support  --->
                                    <M> Blackfin TWI I2C support
                                    (100) Blackfin TWI I2C clock (kHz)
          Device Drivers  --->
                   <M> Multimedia support  --->
                                 [*]   Media Controller API (EXPERIMENTAL)
                           [*]   V4L platform devices  --->
                                       <M>   Blackfin Video Capture Driver
                                 Encoders, decoders, sensors and other helper chips  --->
                                            < > Analog Devices ADV7183 decoder
                                            <M> Analog Devices ADV7842 decoder
                                            < > ST VS6624 sensor support
                                            < > Aptina MT9M114 sensor support
After the build is complete, after the runs on the Board, in the/dev/directory not found video 0 equipment??????
Running log file is as follows
Bytes transferred = 16962915 (102d563 hex)
## Booting kernel from Legacy Image at 01000000 ...
   Image Name:   bf609-0.0-3.5.7-ADI-2012R2
   Image Type:   Blackfin Linux Kernel Image (gzip compressed)
   Data Size:    16962851 Bytes = 16.2 MiB
   Load Address: 00001000
   Entry Point:  0029daec
   Verifying Checksum ... OK
   Uncompressing Kernel Image ... OK
Starting Kernel at = 0029daec
console [ttyBF0] enabled, bootconsole disabled
Calibrating delay loop... 989.18 BogoMIPS (lpj=1978368)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
devtmpfs: initialized
Blackfin Scratchpad data SRAM: 4 KB
Blackfin L1 Data A SRAM: 16 KB (9 KB free)
Blackfin L1 Data B SRAM: 16 KB (16 KB free)
Blackfin L1 Instruction SRAM: 64 KB (51 KB free)
Blackfin L2 SRAM: 256 KB (256 KB free)
NET: Registered protocol family 16
Blackfin DMA Controller
ezkit_init(): registering device resources
ezkit_init(): request emac pins failed
bio: create slab <bio-0> at 0
SCSI subsystem initialized
bfin-spi bfin-spi.0: master is unqueued, this is deprecated
bfin-spi bfin-spi.0: bfin-spi probe success
bfin-spi bfin-spi.1: master is unqueued, this is deprecated
bfin-spi bfin-spi.1: bfin-spi probe success
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
i2c-bfin-twi i2c-bfin-twi.0: Blackfin on-chip I2C TWI Contoller, regs_base@ffc01e00
i2c-bfin-twi i2c-bfin-twi.1: Blackfin on-chip I2C TWI Contoller, regs_base@ffc01f00
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
PTP clock support registered
NET: Registered protocol family 23
Switching to clocksource bfin_cs_cycles
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP: reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
msgmni has been set to 210
io scheduler noop registered (default)
bfin-uart: Blackfin serial driver
bfin-uart.0: ttyBF0 at MMIO 0xffc02000 (irq = 88) is a BFIN-UART
physmap platform flash device: 01000000 at b0000000
physmap-flash.0: Found 1 x16 devices at 0x0 in 16-bit bank. Manufacturer ID 0x000089 Chip ID 0x008821
Intel/Sharp Extended Query Table at 0x010A
Using buffer write method
Using auto-unlock on power-up/resume
cfi_cmdset_0001: Erase suspend on write enabled
Creating 3 MTD partitions on "physmap-flash.0":
0x000000000000-0x000000080000 : "bootloader(nor)"
0x000000080000-0x000000480000 : "linux kernel(nor)"
0x000000480000-0x000001000000 : "file system(nor)"
m25p80 spi0.1: w25q32 (4096 Kbytes)
Creating 3 MTD partitions on "m25p80":
0x000000000000-0x000000080000 : "bootloader(spi)"
0x000000080000-0x000000200000 : "linux kernel(spi)"
0x000000200000-0x000000400000 : "file system(spi)"
CAN device driver interface
bfin_can bfin_can.0: bfin_can device registered(&reg_base=ffc00a00, rx_irq=47, tx_irq=48, err_irq=49, sclk=125000000)
        DWMAC100
No HW DMA feature register supported
Enhanced/Alternate descriptors
RX IPC Checksum Offload not configured.
stmmac_dvr_probe: warning: cannot get CSR clock
stmmac: probed
eth0: PHY ID 20005c90 at 1 IRQ 0 (stmmac-0:01) active
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
input: bfin-rotary as /devices/platform/bfin-rotary/input/input0
i2c /dev entries driver
bfin_wdt: initialized: timeout=20 sec (nowayout=0)
dma_alloc_init: dma_page @ 0x02477000 - 1024 pages at 0x07c00000
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
icc icc.0: initialized
TCP: cubic registered
can: controller area network core (rev 20090105 abi 8)
NET: Registered protocol family 29
Freeing unused kernel memory: 15320k freed
mmc0: host does not support reading read-only switch. assuming write-enable.
mmc0: new SD card at address e624
mmcblk0: mmc0:e624 SU02G 1.84 GiB
mmcblk0: p1
eth0: device MAC address 02:80:ad:20:31:e8
No MAC Management Counters available
BusyBox v1.20.2 (2013-06-09 09:32:39 CST) hush - the humble shell
root:/> PHY: stmmac-0:01 - Link is Up - 100/Full
